I am attempting to resize my VMware VMs with both sunstone and the cli (onevm resize …) without success. The VM is powered off when trying to resize. When resizing thru either sunstone or the cli, the command return as successful.
Command:
onevm resize 32 --cpu 3
From the oned.log:
Mon Aug 24 18:32:44 2015 [Z0][ReM][D]: Req:6560 UID:0 VirtualMachineResize invoked , 32, “CPU = 3.0…”, false
Mon Aug 24 18:32:44 2015 [Z0][ReM][D]: Req:6560 UID:0 VirtualMachineResize result SUCCESS, 32
The change is reflected in Sunstone. No attempt is made to reconfigure the VM in vCenter. OpenNebula is connected to a 6.0 vCenter with full admin rights. I can successfully deploy from a template but not change cpu or memory at deployment. I can power off, poweron, create and commit a snapshot, but cannot add a disk.
Also, does the VMware drivers also need to be configured when working with vCenter?
