I am setting up opennebula on two node cluster (One Head and one Worker node).
I have completed all the installation and configuration part, but stuck at VM creation.
My problem is that I am not able to create more then one VM. If I have one VM which is in running state, all the remaining will go to failed state.
log file for that:
Tue Mar 1 09:45:28 2016 [DiM][I]: New VM state is ACTIVE. Tue Mar 1 09:45:28 2016 [LCM][I]: New VM state is PROLOG. Tue Mar 1 09:47:58 2016 [TM][I]: /usr/lib/ruby/1.8/open3.rb:73: warning: Insecure world writable dir /opt in PATH, mode 040777 Tue Mar 1 09:47:58 2016 [TM][I]: clone: Cloning /var/lib/one/datastores/1/4d03488de689226edda6022fcd90c368 in c4:/var/lib/one//datastores/0/52/disk.0 Tue Mar 1 09:47:58 2016 [TM][I]: ExitCode: 0 Tue Mar 1 09:48:00 2016 [TM][I]: /usr/lib/ruby/1.8/open3.rb:73: warning: Insecure world writable dir /opt in PATH, mode 040777 Tue Mar 1 09:48:00 2016 [TM][I]: context: Generating context block device at c4:/var/lib/one//datastores/0/52/disk.1 Tue Mar 1 09:48:00 2016 [TM][I]: ExitCode: 0 Tue Mar 1 09:48:00 2016 [LCM][I]: New VM state is BOOT Tue Mar 1 09:48:00 2016 [VMM][I]: Generating deployment file: /var/lib/one/vms/52/deployment.0 Tue Mar 1 09:48:01 2016 [VMM][I]: ExitCode: 0 Tue Mar 1 09:48:01 2016 [VMM][I]: Successfully execute network driver operation: pre. Tue Mar 1 09:48:01 2016 [VMM][I]: Command execution fail: cat << EOT | /var/tmp/one/vmm/kvm/deploy /var/lib/one//datastores/0/52/deployment.0 c4 52 c4 Tue Mar 1 09:48:01 2016 [VMM][I]: error: Failed to create domain from /var/lib/one//datastores/0/52/deployment.0 Tue Mar 1 09:48:01 2016 [VMM][I]: error: internal error process exited while connecting to monitor: 2016-02-29T11:12:51.599689Z kvm: Failed to start VNC server on 127.0.0.1:-892’: socket bind failed: Address already in use
Tue Mar 1 09:48:01 2016 [VMM][E]: Could not create domain from /var/lib/one//datastores/0/52/deployment.0
Tue Mar 1 09:48:01 2016 [VMM][I]: ExitCode: 255
Tue Mar 1 09:48:01 2016 [VMM][I]: Failed to execute virtualization driver operation: deploy.
Tue Mar 1 09:48:01 2016 [VMM][E]: Error deploying virtual machine: Could not create domain from /var/lib/one//datastores/0/52/deployment.0
Tue Mar 1 09:48:02 2016 [DiM][I]: New VM state is FAILED`
One thing that I noticed is that, while VM creation is in prolog state and disk0 and disk1 are being made at /var/lib/one/datastores/0/vmname/, the failed VM’s are getting uid and gid = 99(i.e. nobody).
I think that’s what causing it to fail, as for the case of successful one, its’s uid and gid is first oneadmin then qemu.
Either that or that error in the log messages that says address already in use.
I have checked all the file permissions (actually gave all the files in /var/lib/one/, “u+rwx” permission).
And libvirtd is running on worker node.
Thanks a lot knawnd,
I disabled the VNC and the VM’s created just fine. Will try to configure VNC later on, but for now, my system is up and running. Thanks.
Just in case you haven’t already figured out, this is because two VMs using
the same VNC port, review the GRAPHICS section of your templates, specially
PORT.
On Mon, Feb 29, 2016 at 12:49 PM, Amit Sharma wrote:
node).
VM creation.
log file for that:
/var/lib/one/v ms/52/de ployment.0
operation: pre.
52 c4
start VNC server on127.0.0.1:-892’: socket bind failed: Address already
in use
operation: deploy.
Tue Mar 1 09:48:01 2016 [ VMM][E]: Error deploying virtual machine: Could
use.
