Scalable VNC - in Guacamole?
Hi everyone, I have a user that finds the noVNC built into Sunstone a little hard to use, specifically not being able to adjust the virtual screen resolution to fit the browser window on different size monitors. He’s using a Linux desktop. I’ve looked online but I can’t really tell if Guacamole allows more flexibility in adjusting screen sizes in a user-transparent fashion. Does it?
I have got the same problem. Did you resolve that?
Thanks.
are you using the OpenNebula 6.0+ version?
Best,
Sergio
Yes, I’m using 6.0.0.2.
Best,
Dani.
