Hello.
We have now 2 clusters (100 and 102) with nearly the same capabilities except a Lizardfs datastore.
We have older templates/images in a shared qcow2 datastore, usable on both clusters but I would like to restrict some of these template to the old cluster for now.
I added SCHED_REQUIREMENTS=CLUSTER_ID=\"100\"" to a template but this parameter completely disappear in the running VM and the scheduling is not impacted.
I made a test by uncommenting the SCHED_REQUIREMENTS in /etc/one/oned.conf and this time the scheduling is properly impacted and I found the attribute in onevm show -x ID | grep SCHED_REQUIREMENTS.
Our templates are generated by a jenkins user which is not oneadmin.
Is there a way to fulfill the following conditions:
SCHED_REQUIREMENTScan be set by a nononeadminuser -
SCHED_REQUIREMENTSmodify the scheduling policy
OpenNebula 5.8.1
In a dual host environment, with one noted as disabled
- Define a template with
SCHED_REQUIREMENTSto select the disabled host - Start the VM as a normal user
- The VM is scheduled on the enabled host.
- There is no
SCHED_REQUIREMENTSin the output ofonevm show
- The VM should no be scheduled because the selected host is disabled
- The
SCHED_REQUIREMENTSattribute should be in the output ofonevm show
