[SOLVED][one.vm.attachnic] Alias not found
I would like add ip to nic of my VM
I use Opennebula 5.8.0
I would like use option alias
i’ve create a file new-nic.txt
NIC_ALIAS = [ NETWORK = “DCRENNES-VNET-MUTUALISE-CISCO”, PARENT = “NIC0”]
But
[root@virt23 ~]# onevm nic-attach MUT-Swarm01 --file new-nic.txt
[one.vm.attachnic] Alias not found.
I forgot something ?
it’s solved
if you have migrate from 5.6 to 5.8
you should delete the nic and recreate on 5.8 version
