cmonty14
(Thomas Schneider)
March 18, 2022, 4:55pm
1
In the Sunstone WebUI - Dashboard there’s a failure when clicking on a specific icon:
The WebUI gets blank and nothing is working.
The relevant icon is marked in this screenshot:
opennebula-sunstone 6.2.0-1.ce
Open Sunstone WebUI using http://:2616/fireedge/sunstone/
Click on 2nd icon from the right
Sunstone WebUI gets blank and nothing is working
No malfunction when clicking the icon.
sbetanzos
(Sergio Betanzos)
March 21, 2022, 9:14am
2
Hi @cmonty14 ,
Thanks for your feedback about the new Suntone,
The fail that you’re commenting on is caused by the configuration files.
The new Sunstone is work in progress, and it’s configuration files are in constant change. In versions 6.2.x and later, configuration files need to be replaced by the ones that can be downloaded here
Best,
Sergio
cmonty14
(Thomas Schneider)
March 21, 2022, 10:10am
3
after deploying the files the icon has disappeared.
Can you confirm this?
Regards
Thomas
