Sunstone images not showing after installing 4.14 Beta 2
Hi
Since installing 4.14 beta 2 images are not showing up in the sunstone interface except the “ONE” logo image.
Any suggestions?
Thanks
Haydn
This should be fixed with the new beta2 packages, can you download them
again and install?
Thanks
That worked!
The update also fixed another update I had with beta1 where a new vm deployed to a particular host would get stuck in boot state. That issue is now also fixed.
Thanks you!
