I’am deploying 6.1 on a Debian 11 node from scratch, which does work, but after the installation (via minione) Sunstone crashes on start:
root@frontend:/home/vagrant# systemctl status opennebula-sunstone
● opennebula-sunstone.service - OpenNebula Web UI Server
Loaded: loaded (/lib/systemd/system/opennebula-sunstone.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2021-10-16 06:26:39 UTC; 23min ago
Process: 23243 ExecStartPre=/usr/sbin/logrotate -f /etc/logrotate.d/opennebula-sunstone -s /var/lib/one/.logrotate.status (code=exited, status=0/SUCCESS)
Process: 23244 ExecStart=/usr/bin/ruby /usr/lib/one/sunstone/sunstone-server.rb (code=exited, status=1/FAILURE)
Main PID: 23244 (code=exited, status=1/FAILURE)
CPU: 1.639s
Oct 16 06:26:39 frontend systemd[1]: opennebula-sunstone.service: Scheduled restart job, restart counter is at 4.
Oct 16 06:26:39 frontend systemd[1]: Stopped OpenNebula Web UI Server.
Oct 16 06:26:39 frontend systemd[1]: opennebula-sunstone.service: Consumed 1.639s CPU time.
Oct 16 06:26:39 frontend systemd[1]: opennebula-sunstone.service: Start request repeated too quickly.
Oct 16 06:26:39 frontend systemd[1]: opennebula-sunstone.service: Failed with result 'exit-code'.
Oct 16 06:26:39 frontend systemd[1]: Failed to start OpenNebula Web UI Server.
The Sunstone logs at /var/log/one/sunstone.log are empty
Starting it manually (as root) using /usr/bin/ruby /usr/lib/one/sunstone/sunstone-server.rb does bring the server up properly.
I’am using this lab GitHub - EugenMayer/opennebula-lab: Quickly spin up an opennebula lab with a frontend and 2 compute nodes using vagrant for a fully automated installation.
Thanks for any help!
