I have installed a saparate sunstone server 5.1 but It does not start:
service opennebula-sunstone start
Redirecting to /bin/systemctl start opennebula-sunstone.service
Job for opennebula-sunstone.service failed because the control process exited with error code. See "systemctl status opennebula-sunstone.service" and "journalctl -xe" for details.
[root@vdicsunstone01 one]# systemctl status opennebula-sunstone.service
● opennebula-sunstone.service - OpenNebula Web UI Server
Loaded: loaded (/usr/lib/systemd/system/opennebula-sunstone.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Mon 2017-01-23 20:40:12 CET; 17s ago
Process: 11966 ExecStartPre=/usr/sbin/logrotate -s /tmp/logrotate.state -f /etc/logrotate.d/opennebula (code=exited, status=1/FAILURE)
Jan 23 20:40:12 vdicsunstone01 systemd[1]: Starting OpenNebula Web UI Server...
Jan 23 20:40:12 vdicsunstone01 systemd[1]: opennebula-sunstone.service: control process exited, code=exited status=1
Jan 23 20:40:12 vdicsunstone01 systemd[1]: Failed to start OpenNebula Web UI Server.
Jan 23 20:40:12 vdicsunstone01 systemd[1]: Unit opennebula-sunstone.service entered failed state.
Jan 23 20:40:12 vdicsunstone01 systemd[1]: opennebula-sunstone.service failed.
Jan 23 20:25:27 vdicsunstone01 dhclient[2110]: DHCPREQUEST on eth0 to 192.168.50.1 port 67 (xid=0xe5cb047)
Jan 23 20:25:27 vdicsunstone01 dhclient[2110]: DHCPACK from 192.168.50.1 (xid=0xe5cb047)
Jan 23 20:25:27 vdicsunstone01 NetworkManager[610]: <info> [1485199527.2707] dhcp4 (eth0): address 192.168.50.7
Jan 23 20:25:27 vdicsunstone01 NetworkManager[610]: <info> [1485199527.2708] dhcp4 (eth0): plen 24 (255.255.255.0)
Jan 23 20:25:27 vdicsunstone01 NetworkManager[610]: <info> [1485199527.2708] dhcp4 (eth0): gateway 192.168.50.1
Jan 23 20:25:27 vdicsunstone01 NetworkManager[610]: <info> [1485199527.2709] dhcp4 (eth0): server identifier 192.168.50.1
Jan 23 20:25:27 vdicsunstone01 NetworkManager[610]: <info> [1485199527.2709] dhcp4 (eth0): lease time 3600
Jan 23 20:25:27 vdicsunstone01 NetworkManager[610]: <info> [1485199527.2709] dhcp4 (eth0): hostname 'vdicsunstone01'
Jan 23 20:25:27 vdicsunstone01 NetworkManager[610]: <info> [1485199527.2709] dhcp4 (eth0): nameserver '192.168.50.1'
Jan 23 20:25:27 vdicsunstone01 NetworkManager[610]: <info> [1485199527.2709] dhcp4 (eth0): domain name 'vdicube.com'
Jan 23 20:25:27 vdicsunstone01 NetworkManager[610]: <info> [1485199527.2709] dhcp4 (eth0): state changed bound -> bound
Jan 23 20:25:27 vdicsunstone01 dbus[606]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
Jan 23 20:25:27 vdicsunstone01 systemd[1]: Cannot add dependency job for unit microcode.service, ignoring: Unit is not loaded properly: Invalid argument.
Jan 23 20:25:27 vdicsunstone01 dbus-daemon[606]: dbus[606]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
Jan 23 20:25:27 vdicsunstone01 systemd[1]: Starting Network Manager Script Dispatcher Service...
-- Subject: Unit NetworkManager-dispatcher.service has begun start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit NetworkManager-dispatcher.service has begun starting up.
Jan 23 20:25:27 vdicsunstone01 dhclient[2110]: bound to 192.168.50.7 -- renewal in 1430 seconds.
Jan 23 20:25:27 vdicsunstone01 dbus[606]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jan 23 20:25:27 vdicsunstone01 dbus-daemon[606]: dbus[606]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jan 23 20:25:27 vdicsunstone01 systemd[1]: Started Network Manager Script Dispatcher Service.
-- Subject: Unit NetworkManager-dispatcher.service has finished start-up
-- Unit NetworkManager-dispatcher.service has finished starting up.
-- The start-up result is done.
Jan 23 20:25:27 vdicsunstone01 nm-dispatcher[11885]: req:1 'dhcp4-change' [eth0]: new request (2 scripts)
Jan 23 20:25:27 vdicsunstone01 nm-dispatcher[11885]: req:1 'dhcp4-change' [eth0]: start running ordered scripts...
Jan 23 20:28:17 vdicsunstone01 polkitd[612]: Registered Authentication Agent for unix-process:11905:357001 (system bus name :1.37 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Jan 23 20:28:17 vdicsunstone01 systemd[1]: Cannot add dependency job for unit microcode.service, ignoring: Unit is not loaded properly: Invalid argument.
Jan 23 20:28:17 vdicsunstone01 systemd[1]: Starting OpenNebula Web UI Server...
-- Subject: Unit opennebula-sunstone.service has begun start-up
-- Unit opennebula-sunstone.service has begun starting up.
Jan 23 20:28:17 vdicsunstone01 logrotate[11922]: error: cannot stat /etc/logrotate.d/opennebula: No such file or directory
Jan 23 20:28:17 vdicsunstone01 systemd[1]: opennebula-sunstone.service: control process exited, code=exited status=1
Jan 23 20:28:17 vdicsunstone01 systemd[1]: Failed to start OpenNebula Web UI Server.
-- Subject: Unit opennebula-sunstone.service has failed
-- Unit opennebula-sunstone.service has failed.
-- The result is failed.
Jan 23 20:28:17 vdicsunstone01 systemd[1]: Unit opennebula-sunstone.service entered failed state.
Jan 23 20:28:17 vdicsunstone01 systemd[1]: opennebula-sunstone.service failed.
Jan 23 20:28:17 vdicsunstone01 polkitd[612]: Unregistered Authentication Agent for unix-process:11905:357001 (system bus name :1.37, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Any help will be welcome,
Thanks a lot.
