My configuration looks like that, (centos7/arm64). I have compiled the svncterm tool for centos7. Where is the exact location of the svncterm?
Here is the log output, that make sense for the gurus.
[root@node01 ~]# tail -f /var/log/one/novnc.log
192.168.1.100: SSL connection but ‘/self.pem’ not found
192.168.1.100 - - [11/Aug/2018 00:22:53] 192.168.1.100: Plain non-SSL (ws://) WebSocket connection
192.168.1.100 - - [11/Aug/2018 00:22:53] 192.168.1.100: Version hybi-13, base64: ‘False’
192.168.1.100 - - [11/Aug/2018 00:22:53] 192.168.1.100: Path: ‘/?token=zh7ki79st09hfh5d2axy’
192.168.1.100 - - [11/Aug/2018 00:22:53] connecting to: node01:5902
handler exception: [Errno 111] Connection refused
Hi all,
I soon established to connect to the vnc, but terminal close itself suddenly with the following error. I am using Clox/LXD container system.
Could anyone help me or give any clue?
Thanks.
WebSocket server settings:
Listen on :29876
Flash security policy server
No SSL/TLS support (no cert file)
proxying from :29876 to targets in /var/lib/one/sunstone_vnc_tokens
192.168.1.100 - - [17/Aug/2018 22:07:40] 192.168.1.100: Plain non-SSL (ws://) WebSocket connection
192.168.1.100 - - [17/Aug/2018 22:07:40] 192.168.1.100: Version hybi-13, base64: ‘False’
192.168.1.100 - - [17/Aug/2018 22:07:40] 192.168.1.100: Path: ‘/?token=bp4vkboavy3c0449uk3p’
192.168.1.100 - - [17/Aug/2018 22:07:40] connecting to: node01:5902
192.168.1.100 - - [17/Aug/2018 22:08:13] code 400, message Bad request syntax (’\x88\x8f(Y\x9d\x1c+\xb1\xc9}Z>\xf8h\x08:\xf1s[<\xf9’)
Indeed, when I input something on the login prompt and hit the enter it passes the passwd prompt and replied with login incorrect message. Have you ever encountered problem like that?
Thanks for the reply.
