Hello All ;
We faced this issue in our cluster with 3 nodes connected to eternus fujitsu FC storage that’s show 100 full and , I though the issue with monitoring but even if I add a VM that’s show me
[one.vm.deploy] Image Datastore does not support transfer mode: fs_lvm_ssh
The problems you’re describing doesn’t seem to be related, for the Image Datastore does not support transfer mode: fs_lvm_ssh please double check that your image datastore is properly configured as described here: SAN Datastore — OpenNebula 6.2.0 documentation.
For the monitoring issue, it would be useful if you can share the status of the VG (e.g output of vgdisplay for that VG) executed in any of the nodes defined in the BRIDGE_LIST attributes.
root@A06-SS02-AF05-0405:~# vgdisplay
— Volume group —
VG Name vg-one-0
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 4
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 1
Open LV 0
Max PV 0
Cur PV 1
Act PV 1
VG Size <2.00 TiB
PE Size 4.00 MiB
Total PE 524287
Alloc PE / Size 524287 / <2.00 TiB
Free PE / Size 0 / 0
VG UUID g45f3E-FkGM-EJ5C-uAeG-NGQ7-hD8w-rMXAuv
— Volume group —
VG Name ubuntu-vg
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 10
VG Status resizable
MAX LV 0
Cur LV 9
Open LV 9
Max PV 0
Cur PV 1
Act PV 1
VG Size 277.87 GiB
PE Size 4.00 MiB
Total PE 71135
Alloc PE / Size 70896 / <276.94 GiB
Free PE / Size 239 / 956.00 MiB
VG UUID HnAX4E-Li45-MyRi-yu4H-qDOr-6rDU-po7A56
