I would like to test the resizing a VM Capacity/Disk in OpenNebula 4.14 Beta release.
According to the release notes, http://docs.opennebula.org/4.14/user/virtual_resource_management/vm_guide_2.html#id1 , I see I can do this from Sunstone UI and from the “Virtual Resources” - “Templates” - “Instantiate”. On the release notes, I see that when trying to instantiate a VM I should see something like “Disks” and its size and custom attributes field but I don’t see these fields.
I had a look at the sunstone views but I did not see any option for enabling this. Probably, I am not understanding it correctly or maybe, this features is not included on this beta release yet.
In any case, I would appreciate any help on it
Thanks in advance,
Esteban
