There is no suitable system ds
Dear OpenNebula community and developers,
I’m facing an issue that has blocked me for some hours now. After installing and configuring OpenNebula, I downloaded a Centos 7.2 from the MarketPlace and tried to deploy it. Then I get the message that serves as a title for this topic:
Fri Mar 24 15:36:30 2017 [Z0][VM][D]: Found 1 pending/rescheduling VMs.
Fri Mar 24 15:36:30 2017 [Z0][HOST][D]: Discovered 4 enabled hosts.
Fri Mar 24 15:36:30 2017 [Z0][SCHED][D]: Match-making results for VM 1:
Cannot schedule VM, there is no suitable system ds.
Fri Mar 24 15:36:30 2017 [Z0][SCHED][D]: Dispatching VMs to hosts:
VMID Host System DS
I’m running OpenNebula 5.2.1 on SLES 12 SP2 (built rpms from source using the centos7 spec). The frontend sits on a VM which is run in one of the 4 hosts that form the cluster.
oneadmin@…~> onecluster show "clustername"
CLUSTER 0 INFORMATION
CLUSTER TEMPLATE
RESERVED_CPU="“
RESERVED_MEM=”"
HOSTS
3
4
5
6
VNETS
0
DATASTORES
100
oneadmin@… ~> onedatastore show "datastore name"
DATASTORE 100 INFORMATION
USER : oneadmin
GROUP : users
CLUSTERS : 0
TYPE : IMAGE
DS_MAD : fs
TM_MAD : shared
BASE PATH : /var/lib/one/datastores/100
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : 85.7T
FREE: : 85.7T
USED: : 29.3G
LIMIT: : -
OWNER : um-
GROUP : um-
OTHER : u–
DATASTORE TEMPLATE
CLONE_TARGET="SYSTEM"
DISK_TYPE="FILE"
DS_MAD="fs"
LN_TARGET=“NONE"
RESTRICTED_DIRS=”/“
SAFE_DIRS=”/data/OpenNebula/restored_images/"
TM_MAD="shared"
TYPE=“IMAGE_DS”
IMAGES
4
I’ve also checked the oned.log, there are not errors at all, just the repeating message at sched.log. The VM.log just shows:
New state is PENDING
Any help would be much appreciated.
Kind regards,
Oscar
You must add to the cluster a SYSTEM datastore too.
Judging from the output you are using shared IMAGE datastore. So probably you must setup shared SYSTEM datastore too. There are two ways to do it:
A) reconfigure the default SYSTEM datastore - change its TM_MAD from ssh to shared
B) define new SYSTEM datastore with shared TM_MAD
(the datastores of type SYSTEM are using only TM_MAD)
Then, the best option is on the hosts to create symlink with the datastore ID to a shared place. something like
ln -s /path_to_shared_filesystem_for_system_ds/ /var/lib/one/datastores/$SYSTEM_DS_ID/
Also you can add the default FILE datastore to the cluster too. In most common cases the files from there are inserted in the contextualisation ISO so its default settings are OK for starter.
Hope this helps.
Kind Regards,
Dear Anton,
It worked! I just added a SYSTEM FS:
oneadmin@…:~> onedatastore list
100 name 85.7T 100% 0 1 img fs shared on
101 system 85.7T 100% 0 0 sys - shared on
The VM log:
Mon Mar 27 09:31:30 2017 [Z0][VM][I]: New LCM state is PROLOG
Mon Mar 27 09:31:34 2017 [Z0][VM][I]: New LCM state is BOOT
And the sched log:
Mon Mar 27 09:31:28 2017 [Z0][VM][D]: Found 1 pending/rescheduling VMs.
Mon Mar 27 09:31:28 2017 [Z0][HOST][D]: Discovered 4 enabled hosts.
Mon Mar 27 09:31:30 2017 [Z0][SCHED][D]: Dispatching VMs to hosts:
VMID Host System DS
1 6 101
Thanks for your help Anton!
Kind regards,
Oscar
