Hello, I can’t understand why datastore cannot be applied for VM, VM is in pending state:
Persistent or not, doesn’t matter.
Resources should be enough.
Thu Sep 22 18:18:33 2016 [Z0][VM][D]: Found 2 pending/rescheduling VMs.
Thu Sep 22 18:18:33 2016 [Z0][HOST][D]: Discovered 2 enabled hosts.
Thu Sep 22 18:18:33 2016 [Z0][SCHED][D]: Match-making results for VM 15:
Cannot schedule VM, there is no suitable system ds.
Thu Sep 22 18:18:33 2016 [Z0][SCHED][D]: Match-making results for VM 17:
Thu Sep 22 18:18:33 2016 [Z0][SCHED][D]: Dispatching VMs to hosts:
VMID Host System DS
Datastore is created on target node, some images exists there:
[root@vz7-1 109]# ls -ll
total 136132
-rw-rw-r-- 1 oneadmin oneadmin 55506432 Sep 22 11:50 137ac4a4de007dac52eb3722569bd33e
-rw-r–r-- 1 oneadmin oneadmin 1048576000 Sep 22 12:06 71feef6605a7972f78fb8f937e94b95c
-rw-rw-r-- 1 oneadmin oneadmin 41943040 Sep 22 13:05 a49a52780418600c7b7183052e9a479a
-rw-rw-r-- 1 oneadmin oneadmin 41943040 Sep 22 11:50 e997633a0b9b42ccc2c6befc52a1a072
[root@vz7-1 109]# pwd
/var/lib/one/datastores/109
[root@vz7-1 109]#
On sandbox host I’ve created VM, after 36 minutes of the same error:
Thu Sep 22 15:30:57 2016 [Z0][VM][D]: Found 2 pending/rescheduling VMs.
Thu Sep 22 15:30:57 2016 [Z0][HOST][D]: Discovered 2 enabled hosts.
Thu Sep 22 15:30:57 2016 [Z0][SCHED][D]: Match-making results for VM 8:
Thu Sep 22 15:30:57 2016 [Z0][SCHED][D]: Match-making results for VM 9:
Cannot schedule VM, there is no suitable host.
Thu Sep 22 15:30:57 2016 [Z0][SCHED][D]: Dispatching VMs to hosts:
VMID Host System DS
30 mins:
Thu Sep 22 16:06:57 2016 [Z0][VM][D]: Found 2 pending/rescheduling VMs.
Thu Sep 22 16:06:57 2016 [Z0][HOST][D]: Discovered 2 enabled hosts.
Thu Sep 22 16:06:57 2016 [Z0][SCHED][D]: Match-making results for VM 8:
Thu Sep 22 16:06:57 2016 [Z0][SCHED][D]: Match-making results for VM 9:
Thu Sep 22 16:06:57 2016 [Z0][SCHED][D]: Dispatching VMs to hosts:
VMID Host System DS
Thu Sep 22 16:07:27 2016 [Z0][VM][D]: Found 2 pending/rescheduling VMs.
Thu Sep 22 16:07:27 2016 [Z0][HOST][D]: Discovered 2 enabled hosts.
Thu Sep 22 16:07:27 2016 [Z0][SCHED][D]: Match-making results for VM 9:
Thu Sep 22 16:07:27 2016 [Z0][SCHED][D]: Dispatching VMs to hosts:
VMID Host System DS
8 0 104
opend.log
Thu Sep 22 18:15:33 2016 [Z0][ReM][D]: Req:1072 UID:0 VirtualMachineUpdateTemplate result SUCCESS, 15
Thu Sep 22 18:15:33 2016 [Z0][ReM][D]: Req:1872 UID:0 VirtualMachineUpdateTemplate invoked , 17, “<DESCRIPTI…”
Thu Sep 22 18:15:33 2016 [Z0][ReM][D]: Req:1872 UID:0 VirtualMachineUpdateTemplate result SUCCESS, 17
Thu Sep 22 18:15:35 2016 [Z0][InM][D]: Host one-sandbox (0) successfully monitored.
Thu Sep 22 18:15:35 2016 [Z0][VMM][D]: VM 8 successfully monitored: DISK_SIZE=[ID=0,SIZE=40] DISK_SIZE=[ID=1,SIZE=1] STATE=a CPU=6.74 MEMORY=131072 NETRX=1452 NETTX=0
Thu Sep 22 18:15:40 2016 [Z0][InM][D]: Host 10.110.20.151 (4) successfully monitored.
Thu Sep 22 18:15:50 2016 [Z0][InM][D]: Monitoring datastore default (1)
Thu Sep 22 18:15:50 2016 [Z0][InM][D]: Monitoring datastore vz (109)
Thu Sep 22 18:15:50 2016 [Z0][ImM][D]: Datastore default (1) successfully monitored.
Thu Sep 22 18:15:50 2016 [Z0][ImM][D]: Datastore vz (109) successfully monitored.
Thu Sep 22 18:15:55 2016 [Z0][InM][D]: Host one-sandbox (0) successfully monitored.
Thu Sep 22 18:15:55 2016 [Z0][VMM][D]: VM 8 successfully monitored: DISK_SIZE=[ID=0,SIZE=40] DISK_SIZE=[ID=1,SIZE=1] STATE=a CPU=8.04 MEMORY=131072 NETRX=1452 NETTX=0
Thu Sep 22 18:15:58 2016 [Z0][ReM][D]: Req:4400 UID:1 DocumentPoolInfo invoked , -2, -1, -1, 100
Thu Sep 22 18:15:58 2016 [Z0][ReM][D]: Req:4400 UID:1 DocumentPoolInfo result SUCCESS, “<DOCUMENT_POOL></DOC…”
Thu Sep 22 18:16:00 2016 [Z0][InM][D]: Host 10.110.20.151 (4) successfully monitored.
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:8688 UID:0 VirtualMachinePoolInfo invoked , -2, -1, -1, -1
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:8688 UID:0 VirtualMachinePoolInfo result SUCCESS, “<VM_POOL>8</…”
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:5808 UID:0 VirtualMachinePoolInfo invoked , -2, -1, -1, -1
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:5808 UID:0 VirtualMachinePoolInfo result SUCCESS, “<VM_POOL>8</…”
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:320 UID:0 DatastorePoolInfo invoked
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:320 UID:0 DatastorePoolInfo result SUCCESS, “<DATASTORE_POOL><DAT…”
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:5168 UID:0 DatastorePoolInfo invoked
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:5168 UID:0 DatastorePoolInfo result SUCCESS, “<DATASTORE_POOL><DAT…”
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:4576 UID:0 UserPoolInfo invoked
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:4576 UID:0 UserPoolInfo result SUCCESS, “<USER_POOL><ID…”
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:5232 UID:0 HostPoolInfo invoked
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:5232 UID:0 HostPoolInfo result SUCCESS, “<HOST_POOL><ID…”
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:3968 UID:0 ClusterPoolInfo invoked
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:3968 UID:0 ClusterPoolInfo result SUCCESS, “<CLUSTER_POOL><CLUST…”
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:5728 UID:0 AclInfo invoked
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:5728 UID:0 AclInfo result SUCCESS, “<ACL_POOL>0…”
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:1424 UID:0 VirtualMachineUpdateTemplate invoked , 15, “<![C…”
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:1424 UID:0 VirtualMachineUpdateTemplate result SUCCESS, 15
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:5776 UID:0 VirtualMachineUpdateTemplate invoked , 17, “<DESCRIPTI…”
Thu Sep 22 18:16:03 2016 [Z0][ReM][D]: Req:5776 UID:0 VirtualMachineUpdateTemplate result SUCCESS, 17
Thu Sep 22 18:16:05 2016 [Z0][MKP][D]: Monitoring marketplace OpenNebula Public (0)
Thu Sep 22 18:16:05 2016 [Z0][MKP][D]: Marketplace OpenNebula Public (0) successfully monitored.
Thu Sep 22 18:16:20 2016 [Z0][InM][D]: Host one-sandbox (0) successfully monitored.
