Tryin to use OneKE 1.31
Decided to learn kubernetes and wanted to use OneKE 1.31 on 6.10
Followed the instruction and the you tube video and it seems to deploy but my master gives me when I tail -f /var/log/one-appliance/configure.log
[2025-06-11T11:51:39.514126 #1414] INFO – : Set local hostname: oneke-ip-192-168-200-6
I, [2025-06-11T11:51:39.749528 #1414] INFO – : Set this master to be the first VNF backend
E, [2025-06-11T11:51:39.749725 #1414] ERROR – : Invalid IPv4/port for VNF/HAPROXY/0, aborting.
frontend 6.10 running on debiain 12 VM and host is ddebai 12 KVM host
See above
Hello @vizo,
Apologies for the late reply. Could you please share the settings you are entering when you are installing the OneKE appliance?, might be that the parameters you are using aren’t correct.
Regards,
