I’m trying to move to using libgfapi from just a standard NFS mount and I can’t seem to get ONE to feed libvirt the right path in the deployment.0.
Here’s one as an example:
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
<name>one-177</name>
<cputune>
<shares>1024</shares>
</cputune>
<memory>786432</memory>
<os>
<type arch='x86_64'>hvm</type>
<boot dev='hd'/>
</os>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type='network' device='disk'>
<source protocol='gluster' name='gv0/177/disk.0'>
<host name='kvm01' port='24007' transport='tcp'/>
</source>
<target dev='vda'/>
<driver name='qemu' type='qcow2' cache='none'/>
</disk>
<disk type='file' device='cdrom'>
<source file='/var/lib/one/datastores/0/100/177/disk.1'/>
<target dev='hda'/>
<readonly/>
<driver name='qemu' type='raw'/>
</disk>
<interface type='bridge'>
<source bridge='pubbr0'/>
<mac address='XX:XX:XX:XX:XX:XX'/>
</interface>
<graphics type='vnc' listen='0.0.0.0' port='6077'/>
</devices>
<features>
<acpi/>
</features>
The gluster disk in the above isn’t the correct path. The cdrom path is correct though which has me confused. Where is the 100 in
coming from and why isn’t in the
Because if I do:
qemu-img info gluster://kvm01:24007/gv0/177/disk.0
qemu-img: Could not open 'gluster://kvm01:24007/gv0/177/disk.0': Could not open 'gluster://kvm01:24007/gv0/177/disk.0': No such file or directory
it fails, but if I fix the path to this:
qemu-img info gluster://kvm01:24007/gv0/100/177/disk.0
Then it works:
image: gluster://kvm01:24007/gv0/100/177/disk.0
file format: qcow2
virtual size: 10G (10737418240 bytes)
disk size: 830M
cluster_size: 65536
Format specific information:
compat: 0.10
What am I missing? I have the gluster fuse mount mounted per the documentation at:
/var/lib/one/datastores/1 -> /var/lib/one/datastores/0
Any ideas?
