Upgraded from 4.14 to 5.0.1 - Datastore BASE_PATH depreciated
Hi I am hoping someone can point me in the right direction. I recently upgraded oNeb from 4.14 to 5.0.1 and upon doing the database update it said:
“WARNING: The datastore attribute BASE_PATH has been depreciated. It has been removed from the datastore template”. It then gives me instructions to create a symbolic link in the nodes but when I try it… it says failed to create symbolic link: file exists.
The base_path I was using was /var/lib/one/datastores/nas and it wants to link that to /var/lib/one/datastores but it already seems to exist in it.
One more thing - I haven’t yet run onehost sync if that matters… I’m afraid to keep going at this point.
What can I do? Thank you!
~Michael
Administration opennebula@discoursemail.com writes:
I think you may have a problem to link /var/lib/one/datastores/nas to
/var/lib/one/datastores/ since one is under the other.
It may help you, so here is our setup:
We have all our mount points under /var/lib/one/:
  • /var/lib/one/datastores/ a SAN LUN exposed to all hypervisors
  • /var/lib/one/cluster2-datastores/ a SAN LUN dedicated to a VDC with
    its own hypervisors
Then we have two links:
  • /var/lib/one/datastores/103 → /var/lib/one/cluster2-datastores/103
  • /var/lib/one/datastores/104 → /var/lib/one/cluster2-datastores/104
So:
  • all our hypervisors have access to the /var/lib/one/datastores LUN,
    it’s a “common datastores”
  • a VDC has its image and system datastore on a specific SAN LUN,
    exposed only to its own hypervisors
Each datastore mount point is exported by NFS[1] for the frontend:
  • /var/lib/one/datastores is exported by one of all the hypervisors
  • /var/lib/one/cluster2-datastores/ is exported by one of the cluster2
    hypervisors
The frontend mount the NFS shares at the right places for the symlink to work.
Regards.
Footnotes:
[1] I use corosync/pacemaker to have HA NFS
Daniel Dehennin
