mago
(Marc Alcaina)
September 22, 2015, 3:22pm
1
Hi everyone,
I’m new here, my name’s Marc and I started to work with Open Nebula a few months ago.
Now, I have a problem with a persistent Windows Server machine. I need to attach an USB stick to Open Nebula’s Virtual machine but i can’t do it.
¿Is there any way to do that? ¿Is it possible?
jfontan
(Javi Fontán)
October 5, 2015, 1:22pm
2
OpenNebula does not directly support attaching USBs. It does, however, support spice protocol if you are using KVM. Check the SPICE documentation and use a compatible client:
http://www.spice-space.org/download.html
mago
(Marc Alcaina)
January 23, 2017, 4:00pm
3
We still have this problem. Is it possible right now in 2017?
mago
(Marc Alcaina)
January 23, 2017, 4:02pm
4
@jfontan , lo que queremos es dejar un dispositivo USB conectado permanente, no a través de una sesión SPICE. Sabes si esto es posible a día de hoy? Gracias de antemano.
jfontan
(Javi Fontán)
February 6, 2017, 5:32pm
5
You can use the RAW parameter to add libvirt xml into the deployment file. Here’s the libvirt documentation about that:
https://libvirt.org/formatdomain.html#elementsHostDev
This is the same example as in the documentation as a RAW parameter for the VM template:
RAW=[
TYPE="KVM",
DATA="<devices>
<hostdev mode='subsystem' type='usb'>
<source startupPolicy='optional'>
<vendor id='0x1234'/>
<product id='0xbeef'/>
</source>
<boot order='2'/>
</hostdev>
</devices>"]
Probably you don’t need boot order parameter from the example.
