Can I use the dummy drivers to test the IPAM driver? I’m getting some strange results, I must be doing something wrong. I have this XML:
$ cat net1.xml
<IPAM_DRIVER_ACTION_DATA>
<AR>
  <TYPE>IP4</TYPE>
  <IP>10.123.0.10</IP>
  <SIZE>50</SIZE>
</AR>
</IPAM_DRIVER_ACTION_DATA>
I get:
$ base64 net1.xml | /var/lib/one/remotes/ipam/dummy/register_address_range
Traceback (most recent call last):
        4: from /var/lib/one/remotes/ipam/dummy/../../datastore/xpath.rb:62:in `<main>'
        3: from /var/lib/one/remotes/ipam/dummy/../../datastore/xpath.rb:62:in `new'
        2: from /usr/share/ruby/rexml/document.rb:45:in `initialize'
        1: from /usr/share/ruby/rexml/document.rb:288:in `build'
/usr/share/ruby/rexml/parsers/treeparser.rb:28:in `parse': No close tag for /IPAM_DRIVER_ACTION_DATA/AR/IP (REXML::ParseException)
Line: 4
Position: 57
Last 80 unconsumed characters:
        AR=[
          TYPE="IP4",
          IP  ="10.0.0.1",
          SIZE="100",
          NETWORK_MASK="255.255.255.0",
          GATEWAY="10.0.0.1",
          DNS="10.0.0.1",
          IPAM_MAD="dummy"
I have this block in /etc/one/oned.conf and opennebula has been restarted:
IPAM_MAD = [
    EXECUTABLE = "one_ipam",
    ARGUMENTS  = "-t 1 -i dummy"
