Very low bandwidth on VXLAN VNET <10mbit
Hello
I’m trying to use VXLAN network for my guests.
But perfomance is very low.
This is iperf3 test between two VM’s in one VNET within one host:
[ 4] 9.00-10.00 sec 225 KBytes 1.85 Mbits/sec 45 5.46 KBytes
[ 6] 9.00-10.00 sec 233 KBytes 1.91 Mbits/sec 36 6.83 KBytes
[ 8] 9.00-10.00 sec 225 KBytes 1.85 Mbits/sec 44 6.83 KBytes
[ 10] 9.00-10.00 sec 243 KBytes 1.99 Mbits/sec 54 6.83 KBytes
[ 12] 9.00-10.00 sec 231 KBytes 1.89 Mbits/sec 48 6.83 KBytes
[ 14] 9.00-10.00 sec 262 KBytes 2.15 Mbits/sec 44 6.83 KBytes
[SUM] 9.00-10.00 sec 1.39 MBytes 11.6 Mbits/sec 271
When I’m using 802.1 VNET i’m getting about 1.6Gbit on same hardware, that is not very much on 10G net.
I’m using Centos 7 as hosts and Ubuntu from app as VM
What can cause such low speed?
Thanks
Any suggestions?
Does anyone have success with vxlan on centos nodes?
I’m using vxlans no issues which nic are you emulating in the guest VM is it a virtio nic
What OS are you using for hosts?
I’m using centos with 3.10 kernel
Yes, I changed default template from App store to use virtio NIC model
and it fixed everything, thanks
root@ubuntu:~# iperf3 -c 10.229.0.23
Connecting to host 10.229.0.23, port 5201
[ 4] local 10.229.0.22 port 54564 connected to 10.229.0.23 port 5201
[ ID] Interval Transfer Bandwidth Retr Cwnd
[ 4] 0.00-1.00 sec 197 MBytes 1.65 Gbits/sec 1336 274 KBytes
[ 4] 1.00-2.00 sec 230 MBytes 1.93 Gbits/sec 298 593 KBytes
[ 4] 2.00-3.00 sec 279 MBytes 2.34 Gbits/sec 0 864 KBytes
[ 4] 3.00-4.00 sec 280 MBytes 2.35 Gbits/sec 3 872 KBytes
[ 4] 4.00-5.00 sec 309 MBytes 2.59 Gbits/sec 35 1.07 MBytes
[ 4] 5.00-6.00 sec 321 MBytes 2.69 Gbits/sec 162 916 KBytes
[ 4] 6.00-7.00 sec 320 MBytes 2.68 Gbits/sec 271 857 KBytes
[ 4] 7.00-8.00 sec 316 MBytes 2.65 Gbits/sec 0 1.07 MBytes
[ 4] 8.00-9.00 sec 305 MBytes 2.56 Gbits/sec 232 896 KBytes
[ 4] 9.00-10.00 sec 292 MBytes 2.45 Gbits/sec 0 1.08 MBytes
[ 4] 0.00-10.00 sec 2.78 GBytes 2.39 Gbits/sec 2337 sender
[ 4] 0.00-10.00 sec 2.78 GBytes 2.39 Gbits/sec receiver
Great stuff !! I usually just change it in the templates as it’s easy to forget , the default nic it emulates is a 10mb nic which I don’t think anybody these days wants :joy: glad it’s sorted
