Hello all,
I have a physical router 10.10.10.1 and a frontend&host 10.10.10.102.
[oneadmin@localhost ~]$ brctl show
bridge name bridge id STP enabled interfaces
br0 8000.001517895489 yes enp5s0f1
virbr0 8000.000000000000 yes
[oneadmin@localhost ~]$ ifconfig
br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.10.10.102 netmask 255.0.0.0 broadcast 10.255.255.255
inet6 fe80::215:17ff:fe89:5489 prefixlen 64 scopeid 0x20<link>
ether 00:15:17:89:54:89 txqueuelen 0 (Ethernet)
RX packets 1463 bytes 179277 (175.0 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 1868 bytes 562376 (549.1 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp5s0f1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 00:15:17:89:54:89 txqueuelen 1000 (Ethernet)
RX packets 9904 bytes 1776419 (1.6 MiB)
TX packets 10166 bytes 2642482 (2.5 MiB)
device interrupt 19 memory 0xb8800000-b8820000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 0 (Local Loopback)
RX packets 21858 bytes 13623286 (12.9 MiB)
TX packets 21858 bytes 13623286 (12.9 MiB)
virbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1460
inet 192.168.122.1 netmask 255.255.255.0 broadcast 192.168.122.255
ether 00:00:00:00:00:00 txqueuelen 0 (Ethernet)
RX packets 29 bytes 5272 (5.1 KiB)
TX packets 26 bytes 4420 (4.3 KiB)
[oneadmin@localhost ~]$ route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 10.10.10.1 0.0.0.0 UG 0 0 0 br0
10.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 br0
192.168.122.0 0.0.0.0 255.255.255.0 U 0 0 0 virbr0
Using
BRIDGE = "br0"
DNS = "10.10.10.1"
GATEWAY = "10.10.10.1"
GUEST_MTU = "1460"
NETWORK_ADDRESS = "10.10.10.0"
NETWORK_MASK = "255.0.0.0"
PHYDEV = ""
SECURITY_GROUPS = "0"
VLAN_ID = ""
VN_MAD = "dummy"`
my VM receives
alpine-ssh-base-51:~# ifconfig
eth0 Link encap:Ethernet HWaddr 02:00:0A:00:01:01
inet addr:10.10.10.104 Bcast:0.0.0.0 Mask:255.0.0.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:35 errors:0 dropped:0 overruns:0 frame:0
TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2732 (2.6 KiB) TX bytes:1284 (1.2 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1%32571/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
apparently directly from the physical router.
Now I would like to use
BRIDGE = "br0"
DNS = "10.10.10.1"
GUEST_MTU = "1460"
MTU = "1460"
PHYDEV = "enp5s0f1"
VN_MAD = "vxlan"
with a range in 10.0.1.x. However, I get these errors:
[Z0][VMM][D]: Message received: LOG I 52 Command execution fail: /var/tmp/one/vnm/vxlan/pre PFZNPjxJRD41M...
[Z0][VMM][D]: Message received: LOG E 52 pre: Command "sudo ip link add enp5s0f1.2 mtu 1460 type vxlan id 2 group 239.0.0.2 ttl 16 dev enp5s0f1" failed.
[Z0][VMM][D]: Message received: LOG E 52 pre: vxlan: destination port not specified
[Z0][VMM][D]: Message received: LOG I 52 Will use Linux kernel default (non-standard value)
[Z0][VMM][D]: Message received: LOG I 52 Use 'dstport 4789' to get the IANA assigned value
[Z0][VMM][D]: Message received: LOG I 52 Use 'dstport 0' to get default and quiet this message
[Z0][VMM][D]: Message received: LOG I 52 RTNETLINK answers: File exists
[Z0][VMM][D]: Message received: LOG E 52 vxlan: destination port not specified
[Z0][VMM][D]: Message received: LOG E 52 Will use Linux kernel default (non-standard value)
[Z0][VMM][D]: Message received: LOG E 52 Use 'dstport 4789' to get the IANA assigned value
[Z0][VMM][D]: Message received: LOG E 52 Use 'dstport 0' to get default and quiet this message
[Z0][VMM][D]: Message received: LOG E 52 RTNETLINK answers: File exists
[Z0][VMM][D]: Message received: LOG I 52 ExitCode: 2
[Z0][VMM][D]: Message received: LOG I 52 Failed to execute network driver operation: pre.
[Z0][VMM][D]: Message received: DEPLOY FAILURE 52 vxlan: vxlan: destination port not specified
[Z0][VMM][D]: Message received: Will use Linux kernel default (non-standard value)
[Z0][VMM][D]: Message received: Use 'dstport 4789' to get the IANA assigned value
[Z0][VMM][D]: Message received: Use 'dstport 0' to get default and quiet this message
[Z0][VMM][D]: Message received: RTNETLINK answers: File exists
Unsurprisingly
[oneadmin@localhost ~]$ sudo /var/tmp/one/vnm/vxlan/pre PFZNPjxJRD41MjwvSUQ+...
ERROR: pre: Command "sudo ip link add enp5s0f1.2 mtu 1460 type vxlan id 2 group 239.0.0.2 ttl 16 dev enp5s0f1" failed.
ERROR: pre: vxlan: destination port not specified
ERROR MESSAGE --8<------
ERROR MESSAGE ------>8--
[oneadmin@localhost ~]$ sudo ip link add enp5s0f1.2 mtu 1460 type vxlan id 2 group 239.0.0.2 ttl 16 dev enp5s0f1
[oneadmin@localhost ~]$ sudo ip link add enp5s0f1.2 mtu 1460 type vxlan id 2 group 239.0.0.2 ttl 16 dev enp5s0f1 dstport 0
what now? Using
BRIDGE = "br0"
DNS = "10.10.10.1"
GUEST_MTU = "1460"
PHYDEV = ""
VN_MAD = "ovswitch"
yields
[Z0][VMM][D]: Message received: LOG I 52 Command execution fail: /var/tmp/one/vnm/ovswitch/post PFZNPjxJRD41MjwvSUQ+... '/dev/loop1
[Z0][VMM][D]: Message received: LOG I 52 one-52'
[Z0][VMM][D]: Message received: LOG I 52 No tap device found for nic 0
[Z0][VMM][D]: Message received: LOG I 52 ExitCode: 1
[Z0][ReM][D]: Req:6720 UID:0 VirtualMachineInfo invoked , 52
[Z0][ReM][D]: Req:6720 UID:0 VirtualMachineInfo result SUCCESS, "<VM><ID>52</ID><UID>..."
[Z0][InM][D]: Host head1 (2) successfully monitored.
[Z0][ReM][D]: Req:4064 UID:0 VirtualMachineMonitoring invoked , 52
[Z0][ReM][D]: Req:4064 UID:0 VirtualMachineMonitoring result SUCCESS, "<MONITORING_DATA><VM..."
[Z0][VMM][D]: Message received: LOG I 52 ExitCode: 0
[Z0][VMM][D]: Message received: LOG I 52 Successfully execute virtualization driver operation: cancel.
[Z0][VMM][D]: Message received: LOG I 52 Failed to execute network driver operation: post.
[Z0][VMM][D]: Message received: DEPLOY FAILURE 52 ovswitch: -
regardless of whether I put enp5s0f1 as PHYDEV.
I must not have understood something, please point out the right direction.
EDIT: I tried some more:
[oneadmin@localhost ~]$ ip -d link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 promiscuity 0 addrgenmode eui64
2: enp5s0f0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT qlen 1000
link/ether 00:15:17:89:54:88 brd ff:ff:ff:ff:ff:ff promiscuity 0 addrgenmode eui64
3: enp5s0f1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master br0 state UP mode DEFAULT qlen 1000
link/ether 00:15:17:89:54:89 brd ff:ff:ff:ff:ff:ff promiscuity 1 addrgenmode eui64
5: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1460 qdisc noqueue state DOWN mode DEFAULT
link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff promiscuity 0
bridge addrgenmode eui64
6: virbr0-nic: <BROADCAST,MULTICAST> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT qlen 500
link/ether 52:54:00:2a:4b:55 brd ff:ff:ff:ff:ff:ff promiscuity 0
tun addrgenmode eui64
8: enp5s0f1.2: <BROADCAST,MULTICAST> mtu 1460 qdisc noqueue state DOWN mode DEFAULT
link/ether 4a:11:46:c2:71:11 brd ff:ff:ff:ff:ff:ff promiscuity 0
vxlan id 2 group 239.0.0.2 dev enp5s0f1 srcport 0 0 dstport 8472 ttl 16 ageing 300 addrgenmode eui64
20: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT
link/ether 00:15:17:89:54:89 brd ff:ff:ff:ff:ff:ff promiscuity 0
[oneadmin@localhost ~]$ sudo ip link del virbr0-nic
[oneadmin@localhost ~]$ sudo ip link del enp5s0f1.2
deployment with vxlan regenerates enp5s0f1.2 and results in the same errors.
A /var/spool/mail arrived with the following:
sudo: svncterm: command not found
sed: -e expression #1, char 1: unknown command: `,'
but I know as little as ever what to do
