I am attaching Virtual Network to Virtual Router using one.vrouter.attachnic. The state of Virtual Network at the time of attachment is Ready. after attachment if I check the state in VNC console it showing it down. Please help me with this. I am using xml-rpc endpoints for these operations.
- can you do a
ip link set dev [IFACE] up
? - does the Virtual Router add a valid IP on the interface?
- have you tried to set up manually an IP on the interface?
Thank you
