I tried to create virtual router from the vrouter image I have downloaded from Opennebula marketplace and converted to raw image format because for Ceph backend most suitable format in raw image format. But the use case I am trying to implement for Virtual Router is not working. Any support is appreciated.
Opennebula 5.2.1
Ubuntu 14.04
KVM
Need to have ceph storage backend
This is virtual router setup:
virtual n/w1 (10 series)
virtual n/w2(20 series)
virtual router (20.42, 10.11)
vm192 virtual n/w1 (20.43)
vm193 virtual n/w2 (10.12)
I want to ping or connect to vm193 from vm192 (20 to 10 series). How to achieve this with raw image?
Virtual Router Implementation not working
Need to ping from one network to another network with the use of virtual router.
It is working with virtual router qcow2 image but not with raw image. Any help?
