Vm on HOLD after import
when trying to import certain vms, i get " Requested VNC port already assgined to a VM"
after that, the vm is in HOLD mode and i can’t do anything about it. nothing i press works. the vm also appears under Zombies
what can i do? thank you
opennebula version 5.4.13 freshly installed
Can you try with 5.8.1? There has been many improvements since 5.4.x
yes. same problem there
correction. i’ve found that it’s related to the vnc. when i disable the vnc, do deploy, and reconfigure the vnc, it’s fine. thank you
