I have installed the latest OpenNebula 14.4.2 on Debian Jessie in order to play around with the LXCoNe driver.
I have followed the instructions found in the LXCoNe Installation & Configuration Guide to build my playground.
In a couple of hours I had a 2 hosts (frontend and node) environment up and running. One image in raw
format stored in DS 1, one template with CONTEXT[NETWORK=YES], a couple of custom CONTEXT[VAR=VAL] variables, and network connected to (a custom vnet) br0.
Once I instantiate the template, the VM remains in PENDING state forever, if I would have the patience to wait for that long.
$ onetemplate instantiate 1 --name djn
38
$ onevm list
37 oneadmin oneadmin djx runn 0 0K yoda 3d 16h00
38 oneadmin oneadmin djn pend 0 0K yoda 0d 00h38
I have configured the scheduler with LOG[debug_level=5] to inspect the situation further.
$ cat /var/log/one/sched.log
Fri Dec 4 09:40:57 2015 [Z0][SCHED][D]: Getting scheduled actions information. Total time: 0.00s
Fri Dec 4 09:40:58 2015 [Z0][VM][D]: Pending/rescheduling VM and capacity requirements:
ACTION VM CPU Memory PCI System DS Image DS
DEPLOY 38 20 262144 0 13313 DS 1: 0
Fri Dec 4 09:40:58 2015 [Z0][HOST][D]: Discovered Hosts (enabled):
CLUSTER_ID : -1
MEM_USAGE : 0
CPU_USAGE : 0
MAX_MEM : 2058684
MAX_CPU : 100
FREE_DISK : 0
RUNNING_VMS : 0
PUBLIC : 0
DSID FREE_MB
PCI ADDRESS CLASS VENDOR DEVICE VMID
CLUSTER_ID : -1
MEM_USAGE : 262144
CPU_USAGE : 20
MAX_MEM : 2058684
MAX_CPU : 100
FREE_DISK : 0
RUNNING_VMS : 1
PUBLIC : 0
DSID FREE_MB
Fri Dec 4 09:40:58 2015 [Z0][SCHED][D]: Getting VM and Host information. Total time: 0.01s
Fri Dec 4 09:40:58 2015 [Z0][SCHED][D]: Match Making statistics:
Number of VMs: 1
Total time: 0s
Total Match time: 0.00s
Total Ranking time: 0.00s
Fri Dec 4 09:40:58 2015 [Z0][SCHED][D]: Scheduling Results:
Virtual Machine: 38
PRI ID - HOSTS
0 0
-1 2
PRI ID - DATASTORES
0 0
Fri Dec 4 09:40:58 2015 [Z0][SCHED][D]: Dispatching VMs to hosts:
VMID Host System DS
Fri Dec 4 09:40:58 2015 [Z0][SCHED][D]: Dispatching VMs to hosts. Total time: 0.00s
The VM deploy just fine with onevm deploy.
$ onevm deploy 38 2
After a couple of seconds.
$ onevm list
38 oneadmin oneadmin djn runn 0 0K yoda 0d 00h38
$ lxc-attach -n one-38 -- ls -al /tmp/one_env
-rw-r--r-- 1 root root 3878 Dec 4 09:51 /tmp/one_env
Why does this happen? Does it relate to LXC only? That I will find out soon, I haven’t got the chance to test the KVM driver yet with 4.14.2.
Thank you.
