Good day! Friends, I’m a new user of your product, but faced with a problem and all my solutions are not led to success. Problem with the virtual router + networks. When trying to deploy VMS with networks that I have defined to the virtual router, I get an error(configure a virtual router networking and have done according to your instructions via the web interface sunstone):
"Tue Oct 16 22:47:29 2018 [Z0][VM][I]: New state is ACTIVE
Tue Oct 16 22:47:29 2018 [Z0][VM][I]: New LCM state is PROLOG
Tue Oct 16 22:49:25 2018 [Z0][VM][I]: New LCM state is BOOT
Tue Oct 16 22:49:25 2018 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/47/deployment.0
Tue Oct 16 22:49:25 2018 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Tue Oct 16 22:49:26 2018 [Z0][VMM][I]: Command execution fail: /var/lib/one/remotes/vnm/802.1Q/pre PFZNPjxJRD40NzwvSU…
Tue Oct 16 22:49:26 2018 [Z0][VMM][I]: sudo: brctl: command not found
Tue Oct 16 22:49:26 2018 [Z0][VMM][I]: /var/lib/one/remotes/vnm/vlan.rb:162:in get_bridges': undefined methodeach’ for nil:NilClass (NoMethodError)
Tue Oct 16 22:49:26 2018 [Z0][VMM][I]: from /var/lib/one/remotes/vnm/vlan.rb:36:in activate' Tue Oct 16 22:49:26 2018 [Z0][VMM][I]: from /var/lib/one/remotes/vnm/802.1Q/pre:29:in<main>’
Tue Oct 16 22:49:26 2018 [Z0][VMM][I]: ExitCode: 1
Tue Oct 16 22:49:26 2018 [Z0][VMM][I]: Failed to execute network driver operation: pre.
Tue Oct 16 22:49:26 2018 [Z0][VMM][E]: Error deploying virtual machine: 802.1Q: -
Tue Oct 16 22:49:26 2018 [Z0][VM][I]: New LCM state is BOOT_FAILURE "
When I deploy VMS with networks imported from vmware vCenter, there are no such problems. What am I doing wrong? What could be the fault?
Thanks in advance.
OpenNebula 5.4.15; Virtual environment - ESXI 6.5U1, vCenter 6.5; Test VM-Windows Server 2008R2 (vmare Tools 10277).
