What is the use case for "persistent" images?
Last year, I have found out (after reporting a bug) that I’ve always used the “persistent” flag when instantiating a VM wrong.
In essence, I’ve always flagged that option when launching a new VM (in my mind they were “persistent”) and this resulted in a few things:
  • A new image was created for every VM in my “templates” datastore
  • Each VM had its own template
The first bit was a pain, the second turned useful over time - for example for changing parameters and easily re-instantiating.
I’ve now moved to “non persistent” - which works much better for all my intents and purpose but this left me with a question: what is the use case for “persistent” VMs? Am I missing something?
Also, maybe a bit of feedback - the term is probably misleading (and multiple discussions in this forum sort of prove it) - last thing I would have expected is for it to mean that storage will persist to a termination.
Thanks!
Hello.
We use persistent images for production VM where data must survive a terminate.
In addition to locking the VM, we make sure data are never lost.
Regards.
So you consider this flag as a last resort safety net? Someone unlocks by mistake AND terminates by mistake?
How do you handle the datastores? Do you manually copy the tpl or you have a single datastore and are happy with tpls and everything else living in it?
Damn, I’ve just found the use case, two days in. I’ve smashed the kernel on a test instance, so went down the usual path of detaching and attaching the volume to a temporary instance to chroot & fix… Except after detaching, my data was gone.
(I should have copied the volume and fixed there, the problem is that then I would not have been able to restore the qcow2 “tree” and save space)
Sad to here you learned the hard way.
Non persistent images are always cloned to the system datastore and disappear when a VM is terminated or, as you found, the disk detached.
