Hi, recently i got some troubles with qoutas. Default qouta for each user is 2 VM & 2 RVMS. But someway later, users will have 0 VM and at the same time 1 RVM. Like in snippet below:
Thanks
Hello @Jehe
What OpenNebula version are you using?
In order to fix those values, you can use the tool onedb fsck.
Best,
Álex.
5.12.0.3 - current version of ONE.
Yes, fsck helps with those values, but where from error is coming.
Does it happen with all the users or just with some? Can you easily reproduce it?
Best,
Álex.
