5.13.85 + lighttpd SSL, FireEdge public end point not available error
Hi there,
I’ve been following this guide to get OpenNebula using SSL with lighttpd but I’ve run into a problem.
I’ve followed all the steps but I’m getting an error that the fireedge public endpoint isn’t available. Which is strange because I had changed this as per the install doc to be the IP of my OpenNebula install.
Is there an additional step I need to do for fireedge ?
Thanks!
You should also add the fireedge to the lighttpd configuration. By default fireedge is listening on localhost: 2616. After adding it adjust sunstone-server.conf file (with new fireedge url via lighttpd) and restart sunstone service
Got there in the end. I threw away lighttpd for nginx and life improved from there.
Hi, can you share your configuration nginx please.
Kind regards
Pretty much this, change hostname.example.com and the cert paths and you should be good -
/etc/nginx/conf.d/hostname.example.com.conf -
server_tokens off;
#### redirect port 80 to 443
server {
    listen 80;
    server_name hostanme.example.com;
    return 301 https://$server_name;
upstream sunstone  {
    server 127.0.0.1:9869;
upstream fireedge {
    server 127.0.0.1:2616;
upstream websocket_proxy {
    server 127.0.0.1:29876;
server {
    listen 443 ssl;
    server_name hostname.example.com;
    ssl_certificate /etc/nginx/server.crt;
    ssl_certificate_key /etc/nginx/server.key;
    location / {
        if ($args ~* "host=.+&port=.+&token=.+&encrypt=.+") {
            rewrite ^/$ /websockify/ last;
        proxy_pass              http://sunstone;
        proxy_redirect          off;
        log_not_found           off;
        proxy_set_header        X-Real-IP $remote_addr;
        proxy_set_header        X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header        X-Forwarded-Proto $scheme;
    location /websockify {
        proxy_set_header X-Forwarded-Host $host;
        proxy_set_header X-Forwarded-Server $host;
        proxy_set_header x-forwarded-proto  $scheme;
        proxy_set_header Host $host;
        proxy_buffering off;
        proxy_http_version 1.1;
        proxy_read_timeout 86400;
        proxy_pass https://websocket_proxy;
server {
    listen 2617 ssl;
    location / {
        proxy_pass              http://fireedge;
        proxy_pass https://localhost:29876;
In /etc/one/sunstone-server.conf -
# FireEdge
#:private_fireedge_endpoint: http://localhost:2616
#:public_fireedge_endpoint: http://localhost:2616
:public_fireedge_endpoint: https://hostname.example.com:2617
it’s woooooooork :slight_smile:
Thank you
Kind regard
