After enable https on vonecloud Error FireEdge Publicpoint is not working
Hello, after configuring https according to the instructions, I get the error message every time I log in: “FireEdge public endpoint is not working, please contact your cloud administrato.” Unfortunately, I have no idea what the problem could be. Could anyone help me, please?
You should check/fix the last two lines in /etc/one/sunstone-server.conf
If you are not using fireedge, yet, you could comment out both lines and restart the opennebula-sunstone service.
You can find more hints in the docs:
installation and configuration::install
installation and configuration::sunstone
installation and configuration::fireedge
Hope this helps.
Best Regards,
