Ansible one_vm - instantiating with vmgroup and role
I’m trying to use vmgroups. I’ve tested the feature and it works fine using the “instantiate” from sunstone and selecting the vmgroup and role from the UI, but we are using ansible to create our vm’s.
I’ve tried adding the group info to the attributes but that doesn’t do the trick.
Anyone any idea if this is supported in the ansible modules or in python-oca? Or any other suggestions?
thanks,
Sam
