It’s me again with a huge problem. So I was testing a few things with users and changed by mistake the authorization of oneadmin from core to server_cipher when I was going to actually change the serveradmin user.
Is there any way to correct this or should I reinstall the whole thing? It is because I cannot do any OpenNebula commands.
I changed the serveradmin to core in a hope that it will enter the Sunstone GUI but without success so I decided to revert but instead did what I did. Can this core change help in any way?
I have done the following with success, so you can close this problem:
Since I changed the serveradmin to core, it seemed the one chance to correct everything so… I created a new user in my machine with the name serveradmin
Then I logged in the serveradmin account and created the directory .one by issuing $ mkdir .one
I finally changed to that directory and created a file that contained serveradmin:my_password and saved evrything
I performed a check with oneuser show and oneuser list and seemed to work, so I finally performed oneuser chauth oneadmin core
Logged in the oneadmin account and performed all of the different one commands to check. WORKS!
Thanks, hope this can help other people that like me do this mistake.
