Liorme
(lior)
July 21, 2020, 12:13pm
1
i’ve upgraded the system per opennebula’s guide
and now, when i logon to the system, the loading circle turns endlessly and i’m not getting the interface
attached oned.log, i can’t make of it to tell what the problem is
you can see a lot of :
Command execution failed (exit code: 255): /var/lib/one/remotes/datastore/vcenter/monitor
and
block in connect
i don’t know what those mean
thank you
oned.log (72.7 KB)
Did you follow the upgrade from 5.8.x guide ?
It looks like you’ve missed Step 9 .
(And don’t forget to restart the sunstone service after updating the serveradmin password)
Best Regards,
Liorme
(lior)
July 21, 2020, 2:06pm
3
yeah
i already did that. because before i did that, i couldn’t get past the logon screen, i would get an error. maybe i didn’t understand the command?
oneuser passwd --sha256 serveradmin cat /var/lib/one/.one/sunstone_auth|cut -f2 -d':'
should i set it as is? or need i change this to alter something that will match my settings?
i didn’t see in the article something that says i need to alter something in this command
It should be as is.
The plain serveradmin passowd in /var/lib/one/.one/sunstone_auth is used to update the one in the database hashed with sha256
Liorme
(lior)
July 21, 2020, 2:12pm
5
yeah, so it’s probably not that. because as stated, when i didn’t do it, i couldn’t get past the login screen.
So you should try increasing the debug level of sunstone in /etc/one/sunstone-server.conf and check the suunstone log for clues…
It is possible to have issue with cached js files so you should try with different browser or try clearing the browser cache…
Liorme
(lior)
July 21, 2020, 2:22pm
7
i see that it’s on level 3 = debug
about the browser, i already tried another fresh one
if oyou pen the browser’s debug console do you see some kind of js errors?
Liorme
(lior)
July 21, 2020, 2:32pm
9
good idea
got this in errors :
GET http://192.168.199.14/dist/main.js?v=5.10.1 net::ERR_ABORTED 403 (Forbidden)
Liorme
(lior)
July 21, 2020, 2:47pm
10
there seems to bee someone here that had a similar problem and fixed it, but i’m sorry to say it’s above my knowledge
when I login sunstone, I see this as shown in the image below
[Screenshot from 2019-12-05 10-58-43]
I have installed opennebula and built it from source version 5.10.
I am using Ubuntu server18.04.3 LTS
sunstone.error
NOTE: Inheriting Faraday::Error::ClientError is deprecated; use Faraday::ClientError instead. It will be removed in or after version 1.0
Faraday::Error::ClientError.inherited called from /var/lib/gems/2.5.0/gems/zendesk_api-1.22.0/lib/zendesk_api/error.rb:4.
NOTE: Inherit…
looks like a symlink problem of a sort
so what you have in /usr/lib/one/sunstone/public/dist?
in my cluster I have
[root@fe ~]# ls -la /usr/lib/one/sunstone/public/dist
total 15972
drwxr-xr-x 6 root root 175 7 май 16,08 .
drwxr-xr-x 10 root root 325 7 май 16,08 ..
-rw-r--r-- 1 root root 47574 7 май 13,25 build.txt
drwxr-xr-x 2 root root 74 7 май 16,08 console
-rw-r--r-- 1 root root 115201 7 май 13,25 login.js
-rw-r--r-- 1 root root 123132 7 май 13,25 login.js.map
-rw-r--r-- 1 root root 7349845 7 май 13,25 main-dist.js
lrwxrwxrwx 1 root root 29 7 май 16,08 main.js -> /var/lib/one/sunstone/main.js
-rw-r--r-- 1 root root 8705831 7 май 13,25 main.js.map
drwxr-xr-x 2 root root 41 29 авг 2019 opennebula
drwxr-xr-x 13 root root 253 7 май 13,25 tabs
drwxr-xr-x 3 root root 21 7 май 13,25 templates
Liorme
(lior)
July 21, 2020, 3:04pm
12
drwxr-xr-x 5 root root 4096 Jul 21 11:01 .
drwxr-xr-x 9 root root 4096 Jul 21 11:01 …
-rw-r–r-- 1 root root 48249 Dec 10 2019 build.txt
drwxr-xr-x 2 root root 4096 Jul 21 11:01 console
-rw-r–r-- 1 root root 115201 Dec 10 2019 login.js
-rw-r–r-- 1 root root 123129 Dec 10 2019 login.js.map
-rw-r–r-- 1 root root 7316290 Dec 10 2019 main-dist.js
lrwxrwxrwx 1 root root 29 Jul 21 11:01 main.js -> /var/lib/one/sunstone/main.js
-rw-r–r-- 1 root root 8667113 Dec 10 2019 main.js.map
drwxr-xr-x 11 root root 4096 Dec 10 2019 tabs
drwxr-xr-x 3 root root 4096 Dec 10 2019 templates
looks the same i guess
try stopping the sunstone service, rename /var/lib/one/sunstone/main.js and create an empty file instead. then, when you start the sunstone service the file should be re-generated…
Liorme
(lior)
July 21, 2020, 3:22pm
14
yeah, it did regenerate, but nothing changes
the url he’s trying is http://192.168.199.14/dist/main.js?v=5.10.1 and he gets forbidden. but the permissions looks fine
this is a test system. when i do the same on the production with v=5.8.4 i get the content of the main.js file
do you have a reverce proxy in front of the sunstone? Asking because the sunstone service is on port 9869, so the direct URL should be
http://192.168.199.14:9869/dist/main.js?v=5.10.1
Liorme
(lior)
July 21, 2020, 3:34pm
16
no, no probxy. both the original system and this one is on port 80, always has been
