Behaviour of DS_MIGRATE
Hello.
I trying to figure out the use cases of DS_MIGRATE to implement a storage addon:
  • does it cover migration between different TM_MAD or for the same TM_MAD?
  • how does that interact with live migration?
Regards.
Hello @DaD,
I always consult the logic in the sources. There we have:
The migration is allowed only for the same TM_MAD
It depends on the datastore attribute DS_LIVE_MIGRATION defined in the TM_MAD driver configuration.
There are other checks(limitations) around the above-mentioned lines in the code, so it is worth looking around a bit :wink: .
Hope this helps,
Best Regards,
