After I created vm from ISO. i can.t detach iso on vm.
https
://drive.google.com/file/d/0B_vbUiOS2ZSiREFWdmtuZ3pKM1k/view
Help me please.
Thank you .
https
Help me please.
Thank you .
Hi!,
I may be wrong, but the VM is in running state in your video. Have you tried to POWEROFF the VM and detach the ISO?
When you create the image in OpenNebula for the ISO by default I think it uses ide emulation, so you can’t hot unplug an IDE disk as you could not in real world, that’s why you may have to poweroff the VM so you can detach it in a cold state.
Try it and let’s see if that solves your issue.
Cheers!
