Hi.
one user lunch (through) oneflow one vm.
by default the user has USE && MANAGE perms… but… if they stop ( poweroff ) the user can not be able to resize CPU and/or MEMORY… i need to set the perm to ADMIN.
I was looking at doc (ON 4.10.2) to found what can do the user at the VM with perm MANAGE… but not found… and of course… i was looking how change the user perms by default… but… i think only can change setting a new ACL
Its that normal… the MV star only as USE and MANAGE?.. or there are any trouble about my config
Thanks in advance.
