We may have overlooked at it. The assumption is that a BOOT_FAILURE issue
is related to a misconfigured hypervisor, thus something that requires
admin intervention. What was the problem?
We used to generate some template automatically with jenkins, and the
boot order configuration changed from
HD,CDROM
to
disk0,disk1
Fixing it only requires to modify the template.
Regards.
Daniel Dehennin
So, I think that should be addressed as a bug, OpenNebula should complain
about a wrong syntax in the VM Template and not let the user to create such
VM. Any template error should be catched early in the VM life-cycle, and
not go through the cloning process of disk images and so on…
