I’m configuring a OpenNEbula server that acts as Front-End server and as KVM Node. This server has only one NIC (eth). I want to configure ONE in the following way:
- all the instances will run locally because the server acts as KVM node
- eth0 is my public interface, so it’s configured with an public IP address. External connectivity (from outside to inside and from inside to outside) will be throught this interface
- I have installed Openvswitch for bridging
- Also, I have added my public SSH key to my profile
By the moment, I have configured a private network (1.1.1.0/24) inside OpenNebula.
With this configuration, when I launch an instance with that network, it runs OK and OpenNebula-sunstone shows that my instance has got 1 IP from 1.1.1.0/24 range. However, I can’t connect using SSH from the server to the instance private IP address.
However, from my server console, I can’t do “ssh root@private_IP_address” (No route to host)
My openvswitch configuration is:
[root@nebulaserver ~]# ovs-vsctl show
f0b9f453-1630-4ef5-aad2-5eafb8f3f90a
Bridge "br0"
Port "eth0"
Interface "eth0"
Port "br0"
Interface "br0"
type: internal
ovs_version: "2.7.0"
What I’m missing?
Thanks.
