Some days ago, one of my three OpenNebula servers exceeded the value of “overcommitment” in host configuration. As you could see in these two screenshots, my host was at 106% of assigned CPUs, but host was at configured to share its 104 cores, but not more than them:
So my question is if it is a normal behavior of “overcommitment” parameter. My OpenNebula version is 6.8.0-1 and my servers are running Ubuntu Server 22.04.3.
Thanks.
Are all VMs deployed to the host via the OpenNebula scheduler? Wondering because a VM instantiated or migrated to the host by an Administrator could override the limits (oneadmin for example has no limits…)
BR,
Hi @atodorov_storpool
Possibly, in that moment of 106%, some VMs were created using API as a “normal” users (not oneadmin) and not from Sunstone.
Could be that the problem? API? In that case (waiting for your confirmation), is there any way to disable that behavior? How could I force to avoid overcommitment?
Thanks.
