I’m fishing for some ideas here, got a weird behaviour where the disk driver types seem to be not as strict as you’d think they are.
KVM, ONE 5.6
- import SUSE leap 15.0/15.1 vagrant box (ask me for link if you want to try and can’t find)
- machine model i440FX
- set DEV_PREFIX etc. to sd, sda
- do not enable context
- boot
- systemd will hang saying there’s startup jobs running for 2 disk paths (one /dev/sda2, one is a uuid)
vs.
- set DEV_PREFIX etc. to hd, hda
- boot
- system will come up.
- disk will be detected as “sda” will a complete driver attachment as a scsi disk.
sda shows up as sda
setting to hda doesn’t get me a sda.
the drivers are the ones that it should be using - and the system boots even though using systemd.
