Debian packages
Hi all,
I’ve made some customization code change in OpenNebula. Is there scripts available to packaged the binaries and other files in .deb packages for deployment ?
Thanks
Hello @lbeliveau,
Welcome to this forum. I’m not sure about what are you looking, so there’s a couple of options:
  1. To build a specific appliance for a deployment, you can check the One-Apps Project: GitHub - OpenNebula/one-apps: Toolchain to build OpenNebula appliances
  2. If you are looking for the execution of a specific script, perhaps you should check the documentation about hooks: Using Hooks — OpenNebula 6.10.1 documentation
If it’s not connected with any of this, please expand your question a bit, and add more information.
Regards,
Hi @FrancJP !
I’m more looking at packaging what’s in GitHub - OpenNebula/one: The open source Cloud & Edge Computing Platform bringing real freedom to your Enterprise Cloud 🚀. Meaning once “one” repository is compiled, I’d like to package the different binaries and script into a Debian package (.deb) for ease of deployment.
Thank you in advance,
/ludovic
We don’t provide packages scripts, only source packages, e.g.
https://downloads.opennebula.io/repo/6.10/Debian/12/opennebula-6.10.0-1-amd64/source/
Hi @jorel,
Does the packaging scripts are available if I get an enterprise license?
Thanks,
/ludovic
Hello @lbeliveau,
No, the enterprise license doesn’t include those extras, as it states on the FAQ: “The Enterprise Tools available to customers are exclusive tools released with the Enterprise Edition to simplify upgrades and maintenance of OpenNebula clouds in production environments.”
These includes exclusive addons, 24/7 support, and monitoring and reporting tools, among other things.
In any case, if you want to propose a patch, or a enhancement on the core of the platform, I would suggest you to open an issue on the repo: OpenNebula Github Repo
Thanks @FrancJP for the clarifications !
