MartinW
(Martin)
January 12, 2021, 12:15pm
1
Hi all,
Just trying to install a new CentOS host. When I run the “yum install” command it fails with:
https://downloads.opennebula.io/repo/5.12/CentOS/7/x86_64/repodata/repomd.xml: [Errno 14] curl#60 - “Peer’s Certificate has expired.”
I tried retrieving the GPG key directly using wget(1) but that returned:
ERROR: cannot verify downloads.opennebula.io ’s certificate, issued by ‘/C=US/O=Let’s Encrypt/CN=R3’:
Issued certificate has expired.
which I kind-of expected but tried it “just in case”.
Any idea who to speak to about getting the key updated?
vholer
(Vlastimil Holer)
January 12, 2021, 12:30pm
2
Hello @MartinW ,
IMHO server certificate is fine
Issued On Thursday, December 10, 2020 at 2:13:54 PM
Expires On Wednesday, March 10, 2021 at 2:13:54 PM
Do you have correct current time on your machine?
Do you have your system updated?
Can you please provide verbose output from your curl (curl -vvv https://downloads.opennebula.io)?
Thank you,
Vlastimil
MartinW
(Martin)
January 12, 2021, 12:58pm
3
Hi Vlastimil,
Thanks very much for the quick response. It turns out that my carefully-installed ntp daemon hadn’t started and the date was off by about ten months!
Sorting that out has resolved the problem. My apologies for disturbing you with such a simple problem.
|\/|artin
