Failed connect to localhost:2633 ; Connection refused
I have installed open-nebula and it’s installed successfully. But when i point to my IP. I can’t access. and when i checked log then it show this.
Mon Feb 5 02:03:32 2018 [Z0][SCHED][E]: Cannot contact oned, will retry… Error: HTTP POST to URL ‘http://localhost:2633/RPC2’ failed. libcurl failed even to execute the HTTP transaction, explaining: Failed connect to localhost:2633; Connection refused
Please help me to solve this problem
Please search the forum for similar errors first https://forum.opennebula.io/t/failed-to-open-tcp-connection-to-localhost-2633-connection-refused-connect-2-for-localhost-port-2633/ and post a summary if you find a solution in the meantime.
It not useful to me.
i have done all that thing in this blog.But no progress.
This error has been solved
just use this
service iptables save
After that restart the open-nebula services.
It might be run.
