Opennebula is unreachable
Hello team,
I made a new fresh install from source. Evrything is going well. all services is started correctly
I got the login page, then after login , i got “Opennebula is unreachable”
I got no error in log file … i don’t understand where is the problem …
Any ideas ?
Thanks for your help.
Here is log that can help to solve my issue
Cannot contact oned, will retry… Error: libcurl failed to execute the HTTP POST transaction, explaining: Failed to connect to localhost port 2633: Connection refused
The port 2633 is listenning correctly.
curl --data “” http://localhost:2633
it works.
No wrong way
appears just because , the oned process is not ready/started.
I
Finally , i restart my installation from the beginning. It’s working now …
I suspect a problem on my database.
Had the exact same problem on Ubuntu 16.04. No logs…
Reinstalled everything from scratch, and it worked this time…
