When running scons for opennebula-5.10.1 release I have the following compile error
build_bison(["src/parsers/vm_file_var_syntax.cc", "src/parsers/vm_file_var_syntax.h"], ["src/parsers/vm_file_var_syntax.y"])
build_bison(["src/parsers/vm_var_syntax.cc", "src/parsers/vm_var_syntax.h"], ["src/parsers/vm_var_syntax.y"])
scons: *** [src/parsers/vm_var_syntax.cc] src/parsers: No such file or directory
src/rm/RequestManager.cc: In member function 'void RequestManager::register_xml_methods()':
src/rm/RequestManager.cc:357:6: note: variable tracking size limit exceeded with -fvar-tracking-assignments, retrying without
scons: building terminated because of errors.
The files that came with the provided archive are:
expr_arith.cc expr_arith.y expr_bool.h expr_parser.cc expr_parser.l SConstruct template_parser.h template_syntax.cc template_syntax.y vm_file_var_syntax.h vm_var_parser.cc vm_var_parser.l
expr_arith.h expr_bool.cc expr_bool.y expr_parser.h mem_collector.cc template_parser.cc template_parser.l template_syntax.h vm_file_var_syntax.cc vm_file_var_syntax.y vm_var_parser.h vm_var_syntax.y
There is a vm_var_syntax.y but not a vm_var_syntax.cc.
Any hint about the problem?
