Dear All!
Get error:
" `SyntaxError: Unexpected token ...`"on the stage: build the sunstone.
when making:
grunt --gruntfile ./Gruntfile.js sass
Thank you for your response!
OS: CentOS Linux release 7.7.1908 (Core)
Ruby: 2.3.2
npm 3.10.10
git clone https://github.com/OpenNebula/one opennebula-5.10.3
cd opennebula-5.10.3
git checkout tags/release-5.10.3
# manual pages
cd share/man
./build.sh
cd ../../
# sunstone
cd src/sunstone/public
./build.sh -d
export PATH=$PATH:$PWD/node_modules/.bin
./build.sh
full STDOUT of the log :
Writing /builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/bower_components/no-vnc/lib/util/polyfill.js
Writing /builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/bower_components/no-vnc/lib/util/strings.js
+ sed -i -e 's/'\''\.\//'\''\.\.\/bower_components\/no-vnc\/lib\//g' lib/rfb.js
+ PATCH_DIR=./patches/
++ ls ./patches/
ls: cannot access ./patches/: No such file or directory
+ '[' no = yes ']'
+ grunt --gruntfile ./Gruntfile.js sass
/builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/node_modules/mkdirp/lib/opts-arg.js:7
opts = { mode: 0o777, fs, ...opts }
at createScript (vm.js:56:10)
at Object.runInThisContext (vm.js:97:10)
at Module._compile (module.js:549:28)
at Object.Module._extensions..js (module.js:586:10)
at Module.load (/builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/node_modules/coffeescript/lib/coffee-script/register.js:45:36)
at tryModuleLoad (module.js:453:12)
at Function.Module._load (module.js:445:3)
at Module.require (module.js:504:17)
at require (internal/module.js:20:19)
at Object. (/builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/node_modules/mkdirp/index.js:1:79)
at Module._compile (module.js:577:32)
at Object. (/builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/node_modules/grunt/lib/grunt/file.js:20:31)
at gRequire (/builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/node_modules/grunt/lib/grunt.js:14:24)
at Object. (/builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/node_modules/grunt/lib/grunt.js:28:1)
at Module.load (module.js:494:32)
at Liftoff. (/builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/node_modules/grunt-cli/bin/grunt:65:19)
at Liftoff.execute (/builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/node_modules/liftoff/index.js:203:12)
at module.exports (/builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/node_modules/flagged-respawn/index.js:51:3)
at Liftoff. (/builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/node_modules/liftoff/index.js:195:5)
at Liftoff. (/builds/cloud-team/opennebula_builder/opennebula-5.10.3/src/sunstone/public/node_modules/liftoff/index.js:170:7)
at _combinedTickCallback (internal/process/next_tick.js:73:7)
at process._tickCallback (internal/process/next_tick.js:104:9)
Running "sass:dist" (sass) task Done. Running "requirejs:compileCSS" (requirejs) task Running "requirejs:compileJS" (requirejs) task Done.
