Build System info:
- OS: CentOS 7.7
- nodejs: v10.19.0
- npm: 6.13.4
- mock: 2.1
I’m having trouble building OpenNebula 5.10.3 from source using this guide: https://github.com/OpenNebula/packages
I’m able to create the opennebula-5.10.3.tar.gz file fine (I believe). However, when i run the centos7.sh script it fails with this error:
running install_egg_info
running egg_info
writing pyone.egg-info/PKG-INFO
writing dependency_links to pyone.egg-info/dependency_links.txt
writing requirements to pyone.egg-info/requires.txt
writing top-level names to pyone.egg-info/top_level.txt
reading manifest file 'pyone.egg-info/SOURCES.txt'
writing manifest file 'pyone.egg-info/SOURCES.txt'
Copying pyone.egg-info to /builddir/build/BUILDROOT/opennebula-5.10.3-1.el7.x86_64/usr/lib/python3.6/site-packages/pyone-5.10.3-py3.6.egg-info
running install_scripts
+ cd -
/builddir/build/BUILD/opennebula-5.10.3
+ /usr/bin/chmod -R o-rwx /builddir/build/BUILDROOT/opennebula-5.10.3-1.el7.x86_64/var/lib/one/remotes
+ /usr/lib/rpm/find-debuginfo.sh --strict-build-id -m --run-dwz --dwz-low-mem-die-limit 10000000 --dwz-max-die-limit 110000000 /builddir/build/BUILD/opennebula-5.10.3
extracting debug info from /builddir/build/BUILDROOT/opennebula-5.10.3-1.el7.x86_64/usr/bin/oned
extracting debug info from /builddir/build/BUILDROOT/opennebula-5.10.3-1.el7.x86_64/usr/bin/mm_sched
extracting debug info from /builddir/build/BUILDROOT/opennebula-5.10.3-1.el7.x86_64/usr/lib/one/mads/collectd
/usr/lib/rpm/sepdebugcrcfix: Updated 3 CRC32s, 0 CRC32s did match.
cpio: opennebula-5.10.3/expr_arith.cc: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/expr_arith.hh: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/expr_arith.y: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/expr_bool.cc: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/expr_bool.hh: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/expr_bool.y: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/expr_parser.cc: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/expr_parser.h: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/expr_parser.l: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/template_parser.cc: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/template_parser.h: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/template_parser.l: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/template_syntax.cc: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/template_syntax.hh: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/template_syntax.y: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/vm_file_var_syntax.cc: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/vm_file_var_syntax.hh: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/vm_file_var_syntax.y: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/vm_var_parser.cc: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/vm_var_parser.h: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/vm_var_parser.l: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/vm_var_syntax.cc: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/vm_var_syntax.hh: Cannot stat: No such file or directory
cpio: opennebula-5.10.3/vm_var_syntax.y: Cannot stat: No such file or directory
11232 blocks
+ /usr/lib/rpm/check-buildroot
+ /usr/lib/rpm/redhat/brp-compress
+ /usr/lib/rpm/redhat/brp-strip-static-archive /usr/bin/strip
+ /usr/lib/rpm/brp-python-bytecompile /usr/bin/python 1
Bytecompiling .py files below /builddir/build/BUILDROOT/opennebula-5.10.3-1.el7.x86_64/usr/lib/python2.7 using /usr/bin/python2.7
Bytecompiling .py files below /builddir/build/BUILDROOT/opennebula-5.10.3-1.el7.x86_64/usr/lib/python3.6 using /usr/bin/python3.6
+ /usr/lib/rpm/redhat/brp-python-hardlink
+ /usr/lib/rpm/redhat/brp-java-repack-jars
Processing files: opennebula-5.10.3-1.el7.x86_64
RPM build errors:
error: File not found: /builddir/build/BUILDROOT/opennebula-5.10.3-1.el7.x86_64/usr/lib/one/ruby/cli/one_helper/oneflow_helper.rb
error: File not found: /builddir/build/BUILDROOT/opennebula-5.10.3-1.el7.x86_64/usr/lib/one/ruby/cli/one_helper/oneflowtemplate_helper.rb
DEBUG: Child return code was: 1
INFO: EXCEPTION: [Error()]
Traceback (most recent call last):
File "/usr/lib/python3.6/site-packages/mockbuild/trace_decorator.py", line 93, in trace
result = func(*args, **kw)
File "/usr/lib/python3.6/site-packages/mockbuild/util.py", line 755, in do_with_status
raise exception.Error("Command failed: \n # %s\n%s" % (command, output), child.returncode)
mockbuild.exception.Error: Command failed:
# /usr/bin/systemd-nspawn -q -M f8fdae02a2ae41ffbdafa1e6b1d3b106 -D /var/lib/mock/epel-7-x86_64/root --capability=cap_ipc_lock --bind=/tmp/mock-resolv.u02rt1m7:/etc/resolv.conf --bind=/dev/loop-control --bind=/dev/loop0 --bind=/dev/loop1 --bind=/dev/loop2 --bind=/dev/loop3 --bind=/dev/loop4 --bind=/dev/loop5 --bind=/dev/loop6 --bind=/dev/loop7 --bind=/dev/loop8 --bind=/dev/loop9 --bind=/dev/loop10 --bind=/dev/loop11 --setenv=TERM=vt100 --setenv=SHELL=/bin/bash --setenv=HOME=/builddir --setenv=HOSTNAME=mock --setenv=PATH=/usr/bin:/bin:/usr/sbin:/sbin --setenv=PROMPT_COMMAND=printf "\033]0;<mock-chroot>\007" --setenv=PS1=<mock-chroot> \s-\v\$ --setenv=LANG=en_US.UTF-8 --setenv=http_proxy=http://proxy:8888 --setenv=https_proxy=http://proxy:8888 -u mockbuild bash --login -c /usr/bin/rpmbuild -bb --target x86_64 --nodeps /builddir/build/SPECS/centos7.spec
Finish: rpmbuild opennebula-5.10.3-1.el7.src.rpm
Finish: build phase for opennebula-5.10.3-1.el7.src.rpm
ERROR: Exception(/tmp/tmp.GItqlbIyxf/src/opennebula-5.10.3-1.el7.src.rpm) Config(epel-7-x86_64) 6 minutes 21 seconds
INFO: Results and/or logs in: /tmp/tmp.1e9MqdG46F
INFO: Cleaning up build root ('cleanup_on_failure=True')
Start: clean chroot
DEBUG: kill orphans
DEBUG: child environment: None
DEBUG: Executing command: ['/bin/umount', '-n', '-l', '/var/lib/mock/epel-7-x86_64-bootstrap/root/var/lib/mock/epel-7-x86_64/root'] with env {'TERM': 'vt100', 'SHELL': '/bin/sh', 'HOME': '/builddir', 'HOSTNAME': 'mock', 'PATH': '/usr/bin:/bin:/usr/sbin:/sbin', 'LANG': 'en_US.UTF-8'} and shell False
DEBUG: Child return code was: 0
DEBUG: Executing command: ['/bin/umount', '-n', '/var/lib/mock/epel-7-x86_64/root/proc/filesystems'] with env {'TERM': 'vt100', 'SHELL': '/bin/sh', 'HOME': '/builddir', 'HOSTNAME': 'mock', 'PATH': '/usr/bin:/bin:/usr/sbin:/sbin', 'LANG': 'en_US.UTF-8'} and shell False
DEBUG: Executing command: ['/bin/umount', '-n', '/var/lib/mock/epel-7-x86_64/root/var/cache/dnf'] with env {'TERM': 'vt100', 'SHELL': '/bin/sh', 'HOME': '/builddir', 'HOSTNAME': 'mock', 'PATH': '/usr/bin:/bin:/usr/sbin:/sbin', 'LANG': 'en_US.UTF-8'} and shell False
DEBUG: Executing command: ['/bin/umount', '-n', '/var/lib/mock/epel-7-x86_64/root/var/cache/yum'] with env {'TERM': 'vt100', 'SHELL': '/bin/sh', 'HOME': '/builddir', 'HOSTNAME': 'mock', 'PATH': '/usr/bin:/bin:/usr/sbin:/sbin', 'LANG': 'en_US.UTF-8'} and shell False
DEBUG: Executing command: ['btrfs', 'subv', 'list', '/var/lib/mock'] with env {'TERM': 'vt100', 'SHELL': '/bin/sh', 'HOME': '/builddir', 'HOSTNAME': 'mock', 'PATH': '/usr/bin:/bin:/usr/sbin:/sbin', 'LANG': 'en_US.UTF-8'} and shell False
DEBUG: ERROR: not a btrfs filesystem: /var/lib/mock
DEBUG: ERROR: can't access '/var/lib/mock'
DEBUG: Please ignore the error above above about btrfs.
Finish: clean chroot
DEBUG: kill orphans
DEBUG: Executing command: ['/bin/umount', '-n', '/var/lib/mock/epel-7-x86_64-bootstrap/root/proc/filesystems'] with env {'TERM': 'vt100', 'SHELL': '/bin/sh', 'HOME': '/builddir', 'HOSTNAME': 'mock', 'PATH': '/usr/bin:/bin:/usr/sbin:/sbin', 'LANG': 'en_US.UTF-8'} and shell False
DEBUG: Executing command: ['/bin/umount', '-n', '/var/lib/mock/epel-7-x86_64-bootstrap/root/var/cache/dnf'] with env {'TERM': 'vt100', 'SHELL': '/bin/sh', 'HOME': '/builddir', 'HOSTNAME': 'mock', 'PATH': '/usr/bin:/bin:/usr/sbin:/sbin', 'LANG': 'en_US.UTF-8'} and shell False
DEBUG: Executing command: ['/bin/umount', '-n', '/var/lib/mock/epel-7-x86_64-bootstrap/root/var/cache/yum'] with env {'TERM': 'vt100', 'SHELL': '/bin/sh', 'HOME': '/builddir', 'HOSTNAME': 'mock', 'PATH': '/usr/bin:/bin:/usr/sbin:/sbin', 'LANG': 'en_US.UTF-8'} and shell False
ERROR: Command failed:
Thanks in advance for your assistance!
