i’ve failed to understand from instructions on how to make the update
i currently have 5.8.1 and want to go to 5.8.3 (need to stop at 5.8.2 first?)
Quick note: please be aware that 5.8.3 is a hotfix release (ie, packages are available only to OpenNebula Systems support subscribers). Alternatively you can build from source.
Hi, all
I try to build opennebula 5.8.3
I get error when make this step: grunt requirejs
]# grunt requirejs Running "requirejs:compileCSS" (requirejs) task Running "requirejs:compileJS" (requirejs) task >> Error: ENOENT: no such file or directory, open >> '/root/opennebula_builder/opennebula-5.8.3/src/sunstone/public/bower_componen >> ts/no-vnc/lib/rfb.js' >> In module tree: >> main >> tabs/provision-tab >> tabs/provision-tab/vms/list >> utils/vnc Warning: RequireJS failed. Use --force to continue. Aborted due to warnings.
It’s seems was deleted the patch by path:
https://github.com/OpenNebula/one/tree/release-5.8.3/src/sunstone/public/
In 5.8.2 it was:
https://github.com/OpenNebula/one/tree/release-5.8.2/src/sunstone/public/patches//bug4304-novnc.patch
Hello @telecast
That patch is no longer needed, in the 5.8.3 we have upgrade novnc version, so please use sunstone build.sh (src/sunstone/public) script to compile it.
Hi @ahuertas
Great, it’s working.
Thank you for help!
After installed i can’t find file main.js
#ll /usr/lib/one/sunstone/public/dist rw-r--r-- 1 root root 42752 jul 1 17:54 build.txt drwxr-xr-x 2 root root 4096 jul 1 17:54 console -rw-r--r-- 1 root root 113580 jul 1 17:54 login.js -rw-r--r-- 1 root root 121200 jul 1 17:54 login.js.map -rw-r--r-- 1 root root 7227680 jul 1 17:54 main-dist.js -rw-r--r-- 1 root root 8564048 jul 1 17:54 main.js.map drwxr-xr-x 11 root root 4096 jul 1 17:54 tabs drwxr-xr-x 3 root root 4096 jul 1 17:53 templates
probably from this i can’t to enter to Sunstone.
Sunstone get error in console of the web-browser:
/dist/main.js?v=5.8.3 net::ERR_ABORTED 401 (Unauthorized)
Do you have this file /var/lib/one/sunstone/main.js?
Yes, I have
# ll /var/lib/one/sunstone/main.js -rw-r----- 1 oneadmin oneadmin 7229021 jul 1 18:42 /var/lib/one/sunstone/main.js
I have been made the link:
]# ll total 15720 -rw-r--r-- 1 root root 42752 jul 1 18:38 build.txt drwxr-xr-x 2 root root 4096 jul 1 18:38 console -rw-r--r-- 1 root root 113580 jul 1 18:38 login.js -rw-r--r-- 1 root root 121200 jul 1 18:38 login.js.map -rw-r--r-- 1 root root 7229021 jul 1 18:38 main-dist.js lrwxrwxrwx 1 root root 29 jul 1 19:56 main.js -> /var/lib/one/sunstone/main.js -rw-r--r-- 1 root root 8565645 jul 1 18:38 main.js.map drwxr-xr-x 2 root root 4096 jul 1 18:38 sunstone drwxr-xr-x 11 root root 4096 jul 1 18:38 tabs drwxr-xr-x 3 root root 4096 jul 1 18:38 templates
after restart opennebula-sunstone.
Now, ок.
But I have error with noVNC when i click on it:
VNC Failed Something went wrong, connection is closed
I think it happened because when run “grunt requirejs” didn’t find “rfb.js” by path /src/sunstone/public/bower_components/no-vnc/lib/rfb.js
It’s seems was my local bug. Now noVNC is working correctly.
Thank you
