I just wanted to write some feedback about OpenNebula 4.14.2 release to share with you
First of all, I would like to say that we have upgraded successfully our test environment to the 4.14.2 release from the 4.12.1 and we also have run the first 3D modelling test by using Blender in an Ubuntu Desktop VM with GPUs configured on it since now it is possible to configure/pass GPU on the VM template.
We still need to test old and new OpenNebula features but I wanted to share some comments about the upgrade:
If the OpenNebula head node, the Sunstone server and the AppMarket server are not installed on the same machine, it is necessary to install the opennebula-server package on the Sunstone Server in order to be able to start the Sunstone services.
It is necessary to pay attention to the Sunstone views since the yaml configuration files of the views have changed (/etc/one/sunstone-views/*.yaml). Basically, now there is not the true/false at the enable_tabs section and it is configured on the following way, for example:
enabled_tabs:
dashboard-tab # Enable #- system-tab # Disable
To upgrade the AppMarket is necessary to edit the /usr/lib/one/sunstone/public/app/main.js file on the Sunstone server and then compile it. For compiling it, these are the main steps to follow:
If I am not missing anything right now, I think those are the main things to have in account for upgrading to the 4.14.2 release so I hope it helps to the community and also please, feel free open to comment or to add also your experience/recommendations with the upgrade
I haven’t had much luck as you, but of course my installation is not an upgrade, but a full install from scratch. I have this current ticket open where the ec2_hybrid portion of the gems does not install due to an error:
Besides this issue the only other one that I have installing from source is that when I log into the console I do not see the version updated at the bottom of the UI to 4.14.2, it is still 4.14.1.
Are you using the same repo?
If I install the RPM version from the following repo, it is the right version:
Good to know. I guess the master is more like your beta branch, where the subbranches, some of them like one-414, are the stable versions. I’ll be building from this from now on and not raise tickets on master. Sorry for the confusion on my part.
I followed the steps mentioned by @esfreire but I haven’t had the same luck as him, after compile main.js, my opennebula-sunstone does not start, the output of systemctl status opennebula-sunstone shows this:
[root@opennebula01 app]# systemctl status opennebula-sunstone
● opennebula-sunstone.service - OpenNebula Web UI Server
Loaded: loaded (/usr/lib/systemd/system/opennebula-sunstone.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since mié 2016-03-16 14:00:46 CET; 3h 50min ago
Process: 26934 ExecStart=/usr/bin/ruby /usr/lib/one/sunstone/sunstone-server.rb (code=exited, status=1/FAILURE)
Main PID: 26934 (code=exited, status=1/FAILURE)
mar 16 14:00:46 opennebula01 ruby[26934]: from /usr/share/ruby/psych.rb:299:in `open'
mar 16 14:00:46 opennebula01 ruby[26934]: from /usr/share/ruby/psych.rb:299:in `load_file'
mar 16 14:00:46 opennebula01 ruby[26934]: from /usr/lib/one/sunstone/models/SunstoneViews.rb:45:in `block in initialize'
mar 16 14:00:46 opennebula01 ruby[26934]: from /usr/lib/one/sunstone/models/SunstoneViews.rb:42:in `each'
mar 16 14:00:46 opennebula01 ruby[26934]: from /usr/lib/one/sunstone/models/SunstoneViews.rb:42:in `initialize'
mar 16 14:00:46 opennebula01 ruby[26934]: from /usr/lib/one/sunstone/sunstone-server.rb:140:in `new'
mar 16 14:00:46 opennebula01 ruby[26934]: from /usr/lib/one/sunstone/sunstone-server.rb:140:in `<main>'
mar 16 14:00:46 opennebula01 systemd[1]: opennebula-sunstone.service: main process exited, code=exited, status=1/FAILURE
mar 16 14:00:46 opennebula01 systemd[1]: Unit opennebula-sunstone.service entered failed state.
mar 16 14:00:46 opennebula01 systemd[1]: opennebula-sunstone.service failed.
