After building minified JS and CSS files, Sunstone begin to falls with error
]# cat /etc/*release CentOS Linux release 7.5.1804 (Core) ]# rpm -qa | grep opennebula-sunstone opennebula-sunstone-5.6.0-1.noarch ]# rpm -qa | grep nodejs nodejs-8.11.4-1nodesource.x86_64 ]# npm -v 5.6.0
- Install sunstone
- Make these steps (http://docs.opennebula.org/5.6/integration/references/sunstone_dev.html#sunstone-development-dependencies)
3.Building minified JS and CSS files
# grunt saas Loading "sass.js" tasks...ERROR >> Error: Node Sass does not yet support your current environment: Linux 64-bit with Unsupported runtime (57) >> For more information on which environments are supported please see: >> https://github.com/sass/node-sass/releases/tag/v3.13.1 Warning: Task "saas" not found. Use --force to continue. Aborted due to warnings.
- Run the following command to generate the minified files
]#grunt requirejs Loading "sass.js" tasks...ERROR >> Error: Node Sass does not yet support your current environment: Linux 64-bit with Unsupported runtime (57) >> For more information on which environments are supported please see: >> https://github.com/sass/node-sass/releases/tag/v3.13.1 Running "requirejs:compileCSS" (requirejs) task Running "requirejs:compileJS" (requirejs) task Done.
# systemctl status opennebula-sunstone ● opennebula-sunstone.service - OpenNebula Web UI Server Loaded: loaded (/usr/lib/systemd/system/opennebula-sunstone.service; enabled; vendor preset: disabled) Active: failed (Result: exit-code) since Вт 2018-09-11 18:34:17 MSK; 6s ago Process: 32390 ExecStart=/usr/bin/ruby /usr/lib/one/sunstone/sunstone-server.rb (code=exited, status=1/FAILURE) Process: 32387 ExecStartPre=/usr/sbin/logrotate -f /etc/logrotate.d/opennebula-sunstone -s /var/lib/one/.logrotate.status (code=exited, status=0/SUCCESS) Main PID: 32390 (code=exited, status=1/FAILURE) сен 11 18:34:17 csor.jinr.ru ruby[32390]: :session_expire_time=>3600} сен 11 18:34:17 csor.jinr.ru ruby[32390]: -------------------------------------- сен 11 18:34:17 csor.jinr.ru ruby[32390]: /usr/lib/one/ruby/OpenNebulaAddons.rb:29:in `initialize': No such file or directory - /usr/lib/one/sunstone/public/dist/main-dist.js (Errno::ENOENT) сен 11 18:34:17 csor.jinr.ru ruby[32390]: from /usr/lib/one/ruby/OpenNebulaAddons.rb:29:in `new' сен 11 18:34:17 csor.jinr.ru ruby[32390]: from /usr/lib/one/ruby/OpenNebulaAddons.rb:29:in `initialize' сен 11 18:34:17 csor.jinr.ru ruby[32390]: from /usr/lib/one/sunstone/sunstone-server.rb:198:in `new' сен 11 18:34:17 csor.jinr.ru ruby[32390]: from /usr/lib/one/sunstone/sunstone-server.rb:198:in `' сен 11 18:34:17 csor.jinr.ru systemd[1]: opennebula-sunstone.service: main process exited, code=exited, status=1/FAILURE сен 11 18:34:17 csor.jinr.ru systemd[1]: Unit opennebula-sunstone.service entered failed state. сен 11 18:34:17 csor.jinr.ru systemd[1]: opennebula-sunstone.service failed.
For the version 5.4 I make same the steps - it’s worked fine!
In documentation I hadn’t found any different between version 5.4 and 5.6 (http://docs.opennebula.org/5.6/integration/references/sunstone_dev.html)
I probably badly searched…
Have anyone such the problem for the version of sunstone 5.6 was?
How can these problem to solve?
Thanks
